AAAARRRRGGGG!!! Electrical gremlins everywhere!!!
Old Apr 2, 2002 | 02:57 PM
ASRoff's Avatar
ASRoff
Default AAAARRRRGGGG!!! Electrical gremlins everywhere!!!
:mad I have so many gremlins right now I just hope the car doesent burn down!!! heres my current list I'm wondering if the body control module is at fault. most of these simptoms only show up when its raining (clue #1) here goes; 1. The interior lights have a mind of their own they come on and off when they feel like it. More pronounced while raining. 2.cruise control doesent work in the rain. 3.After a heavy rain as I turn the key to start the car the alarm will sound with the car running. I then have to cycle the key to get it to stop. Now this next one Is a PCM problem (I think) I dont have a tach signal the tach is dead and as a result the ASR service light is on I think that if I get the tach signal back ASR should be OK. Any wireing Gurus your thoughts would be apreciated before I attack this thing with my ohm meter.
Old Apr 2, 2002 | 03:55 PM
merrick's Avatar
merrick
Default Re: AAAARRRRGGGG!!! Electrical gremlins everywhere!!! (ASRoff)
The wire bundle connector at the firewall is probably your problem. The dieletric grease maybe dried out and/or water is getting in it. Be sure to clean out all the old dieletric grease.
Old Apr 2, 2002 | 04:08 PM
rideklein's Avatar
rideklein
I've found that when multiple things are going wrong, there's generally a bad ground somewhere to be found that's common to all faulty systems.
Good luck!
Old Apr 2, 2002 | 04:20 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Default Re: AAAARRRRGGGG!!! Electrical gremlins everywhere!!! (Seattle 6spd)
My bet is with Seattle 6spd. Ground.
Old Apr 2, 2002 | 11:50 PM
ASRoff's Avatar
ASRoff
Default Re: AAAARRRRGGGG!!! Electrical gremlins everywhere!!! (FrankUrbinati)
Well guys, I added 2 extra grounds between the engine and the frame when I installed the radio I dont think its a ground problem but I'll re-check the connections (Never assume, right guys?). Merrick I think your probably on to it I figure it has to be where all of these circuits meet I'll check it out. Thanks for your suggestions (keep em' coming) I'll definatly will post my findings.
To AAAARRRRGGGG!!! Electrical gremlins everywhere!!!
