Tire width
Old Oct 20, 2010 | 08:47 PM
surfer93's Avatar
surfer93
Default Tire width
Buying new rims and I have a question.
How wide of a tire can I put on with a 6", 7" and 8" rims?
Old Oct 20, 2010 | 10:32 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Just a guess but I'd take inches * 25 to come up with a good width.
6" * 25 = 150
Then you need to figure the aspect to come with a size that someone makes.
You want your total diameter to be close to your stock wheel/tire combo.
For those sticklers out there I know 1" is approximately 25.4mm. The estimate should give him some wiggle room. He may not be able to find a 150 tire, a 155 would work for his 6" rim
Old Oct 22, 2010 | 06:26 PM
surfer93's Avatar
surfer93
That does not make sense, I have 285's on my 9".
Old Oct 22, 2010 | 06:38 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Your best be is to go to the tire manufacturers website, and look at the specs for the tire you are considering.
Tire Rack will also list the specs.
All tires will have a recommended rim width measurement. Stay within that range, and you'll be fine.
You could also give a little more information of exactly what your looking for.
Not sure what year Corvette your talking about, but I know my '96 didn't have 6", 7", or 8" rims.
Front: 8.5" with a 255/45-17 tire
Rear: 9.5" with a 285/40-17 tire
Any wider than those, your going to need to use a wider rim.
Old Oct 22, 2010 | 09:37 PM
surfer93's Avatar
surfer93
Sorry, just picked up a 70.
Old Aug 23, 2023 | 11:35 AM
Lucifer90's Avatar
Lucifer90
Cool sufer93 , I have 285-25-22 on my 99.
To Tire width
