Brake Question - Hard Pedal
Old Oct 21, 2010 | 01:19 PM
1bigjim's Avatar
1bigjim
Default Brake Question - Hard Pedal
I have owned this car(1987) for 16 years 49K miles and do not drive it more much as I am getting older (49) This year the brakes felt stiff, you have to push hard on the pedal to stop the car. I have replaced all rotors, pads, flushed all the fluid ,and even the power brake booster as it hissed when you stepped on the pedal. That was the last fix and I thought for sure it was the booster. Anyway I don't think this car could stop on a dime if I pressed with one foot on the pedel and one on the ground.
Any idea's boys?
Old Oct 21, 2010 | 05:08 PM
sailorsteve's Avatar
sailorsteve
Some on the forum have found that with a hard pedal issue, if they go to a safe area and make several stops hard enough to trigger the abs, the normal pedal function returns.
Old Oct 21, 2010 | 10:39 PM
8valve's Avatar
8valve
I too had a hard pedal on my 87 I bought earlier this summer.
As mentioned, I went out on a dirt road and made 5 hard stops
to activate the ABS. The pedal feels great now and the brakes are much better. GIve it a try.....its free.
8Valve
Old Oct 22, 2010 | 09:11 AM
red 90's Avatar
red 90
Did you have a ABS light on at the time??
Old Oct 22, 2010 | 09:26 AM
anciano's Avatar
anciano
Yup.
Old Oct 22, 2010 | 10:49 AM
8valve's Avatar
8valve
No, no ABS Light On, just a hard pedal. The brakes worked ok but hard pedal. After the hard stops on dirt activating the ABS, the pedal now is a normal feeling and brakes are all so much better. Part of this winters work is tearing the brake system down and inspecting and replacing needed parts.
8Valve.
Old Oct 22, 2010 | 10:53 AM
red 90's Avatar
red 90
8Valve.
Well mine has the same symtoms but the light is on. Thanks, Mark
To Brake Question - Hard Pedal
