procedure to remove Hypertech
Old Oct 21, 2010 | 09:44 PM
Applied's Avatar
Applied
Cruising
Default procedure to remove Hypertech
What is the process to remove the Hypertech Chip in a 93 Corvette, The other question is it even worth removing since it is already in. I recently purchased the car and the only mods are the Hypertech, Corsa SS Exhaust and K&N air filter. I have heard the car is quicker without it while some say it is quicker with it????
Old Oct 21, 2010 | 09:55 PM
jjgkdg's Avatar
jjgkdg
Do you have a factory chip to replace it?
Old Oct 21, 2010 | 10:16 PM
Applied's Avatar
Applied
Cruising
The way i understand it the 92 and 93 use a piggyback chip so the factory one is also installed. I figure it should be as simple as pulling the hyper-tech out and leaving the factory chip. Does the battery need to be disconnected? I would assume yes.
To procedure to remove Hypertech
