Driveshaft installation
Old Oct 22, 2010 | 05:19 PM
Thomastp's Avatar
Thomastp
Default Driveshaft installation
I have a 94 coupe six speed. I'm in the process of installing the slip yoke on the driveshaft. I have a balance weight on one end of the shaft. Where does it go,towards the differential or the transmission? Does it make any difference?
Old Oct 25, 2010 | 10:19 PM
SJW's Avatar
SJW
The balancing weight should be at the rear end of the shaft. Install the u-joint into the driveshaft first, then install the yoke on the u-joint. Be sure the u-joints you're installing have the anti-galvanic coating on them.
Live well,
SJW
Old Oct 25, 2010 | 11:06 PM
rodj's Avatar
rodj
Why?
Old Oct 26, 2010 | 11:33 PM
SJW's Avatar
SJW
Originally Posted by rodj
Why?
That's where the factory placed it. As well, the FSM procedure for balancing a shaft using the two-hose-clamp method instructs that the clamps should be placed at the rear of the shaft. I don't recall ever seeing a balance weight at the front of a shaft in any car. I, too, have often wondered why this is, but never bothered to ask anybody who knows the answer.
Live well,
SJW
Old Oct 27, 2010 | 02:25 AM
rodj's Avatar
rodj
My C4 DS (stock ) has a weight at both ends.
Which one goes at the rear?
Old Oct 27, 2010 | 08:35 AM
SJW's Avatar
SJW
Good question! I can't answer that one. Maybe it really doesn't matter.
Live well,
SJW
Old Oct 27, 2010 | 07:07 PM
rodj's Avatar
rodj
My take on it.
The DS is balanced by itself to be neutral both ends so it shouldn't matter which end weight is at?
Old Oct 27, 2010 | 10:33 PM
SJW's Avatar
SJW
My take on it.
Makes sense to me. But are you sure the C4 shaft is neutral balanced? I'm wrestling with a driveshaft balance problem right now, and have been reading the FSM on this topic. It makes a point of instructing that the shaft should be installed with the paint mark on the shaft 180* opposite from the paint mark on the pinion shaft, saying that "This aligns the light side of the propeller shaft with the heavy side of the pinion yoke, minimizing residual unbalance."
Live well,
SJW
To Driveshaft installation
