My L98 has an adjustable TPS and I have it set to .65Vdc, the max before the ECM throws a code. When I hit the throttle on a roll the back end comes lose big time.
Your problem may not be the TPS but I think it might help. Maybe some guys with LT1s will come in with a better answer.
What you're describing is similar to a bog with a carbed engine.
I cured mine the same way by raising the TPS voltage to .64. I settled on this after trying everything from .55 up. When I set it at .64 the problem was cured so I left it there.
Each engine combo is different though, so yours may need more or less. I know that some engines don't allow this TPS voltage adjustability, but I believe the aftermarket has a electrical plug-in deal that can be used to raise the voltage - don't know how well it works though.
Matt, I'm not an LT1 guy but I don't think you need any aftermarket stuff here; you have a problem! All these sub 2 second 60' LT1's don't have this tip in problem.
Personally I would look for a failed TPS sensor or vacuum leak. Perhaps the egr is stuck slightly open from carbon buildup or any number of thinks could be wrong.
Best think would be to get a scanner on the car, fuel pressure guage and perhaps a vacuum guage and see what's going on.
It should pull when you hit the go pedal. You don't need aftermarket parts, you need to find out whats broken. :yesnod:
