Direct fit header
Old Apr 2, 2002 | 11:22 PM
Corvette0096's Avatar
Corvette0096
Default Direct fit header
There any out there for a 85 vette with a auto and the heads are going to be the "D" ports. I want some thing that all the a\c brackets will bolt up. So what i am saying is like a oem fit.
Old Apr 3, 2002 | 12:30 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Direct fit header (corvette0096)
Check out the TPIS full length. They make a "bolt up" set for my '88 with D-ports. You might verify with them that all brackets will attach too.
Old Apr 3, 2002 | 11:34 AM
Corvette0096
Default Re: Direct fit header (65Z01)
Looks like there will be some issues with the front "Y" pipe. Those are the long tubes are the short tubes direct fit?
Old Apr 3, 2002 | 02:23 PM
CFI-EFI's Avatar
CFI-EFI
The connection to the cat is different between the '85 and the '88. I am not aware of a TRUE bolt on set for the '85. Close, but not bolts only.
To Direct fit header
