Ecm/pcm flash or chip?
Old Oct 24, 2010 | 08:52 PM
backtothe1980z's Avatar
backtothe1980z
Default Ecm/pcm flash or chip?
I have an 87 that i have done a few mods to and i was wondering should i have a chip made for the computer to adjust for the mods or should i just have the computer flashed? I am just wondering what is better.
Old Oct 25, 2010 | 12:12 AM
rodj's Avatar
rodj
Originally Posted by corvettemania87
I have an 87... should i have a chip made for the computer or should i just have the computer flashed?.
As you note you have a removable chip.
Either the chip gets reprogrammed or you buy a aftermarket tune ( on a chip )
ECM's with chips can't be re-flashed like the later PCM 's with internal memory can be
Old Oct 25, 2010 | 06:59 AM
backtothe1980z
Ok. thanks. I understand now.
Old Oct 25, 2010 | 09:42 PM
backtothe1980z
do you know of a good place to get a custom chip made for my c4?
Old Oct 25, 2010 | 09:49 PM
THE 383 admiral's Avatar
THE 383 admiral
what mods have you completed
I have been tuning TPI proms for 5 years now
take a peek at my last build good speakers are a must
http://www.youtube.com/watch?v=Fqz6tAXC3mk
Old Oct 25, 2010 | 11:10 PM
rodj's Avatar
rodj
http://www.pcmforless.com/index.php?...id=2&Itemid=43
Old Oct 26, 2010 | 08:15 AM
backtothe1980z
thank you rodj
I have only done a few mods: 52 mm throttle body, 1" spacer, true duel exhaust no cats, no smog pump,done away with vats, and i need the cold start injector done away with. need fan set, and i have bigger wheels and tires.
Can you help with this THE 383 admiral
Old Oct 27, 2010 | 11:37 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
Why do you need the cold start injector done away with?
Old Nov 4, 2010 | 06:21 AM
backtothe1980z
I just had got my new chip from pcmforless and i got it installed. They tell me i have to set the TPS and the IAC now back to factory specs. Is there a way to do this without having to take to a mechanic and hook up to a scanner?
Old Nov 4, 2010 | 07:17 AM
vetteoz's Avatar
vetteoz
i have to set the TPS and the IAC . Is there a way to do this without having to take to a mechanic and hook up to a scanner?
Got a DVM ?
http://www.corvetteactioncenter.com/...and+Idle+Speed
Did they give you a idle rpm to adjust to?
Old Nov 4, 2010 | 08:56 AM
backtothe1980z
Originally Posted by vetteoz
Got a DVM ?
I do have a DVM. Yes they recommend 700 rpm at idle. I will try that link you have on your post. I don't want to sound stupid but i am new at this and i want to do this right so i need to know where the IAC plug is? I know where the TPS is.
Old Nov 4, 2010 | 03:38 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
Its the square 4 pin plug under the TPS plug. The TPS socket points towards the front whereas the IAC socket points towards the passenger side
Old Nov 4, 2010 | 06:33 PM
backtothe1980z
Thanks man. I found it.
Old Nov 4, 2010 | 06:34 PM
backtothe1980z
Got a DVM ?
Thanks man for the advice. It really worked and my car is running great!
To Ecm/pcm flash or chip?
