Identifying a ZO7 corvette?????????
Apr 3, 2002 | 12:12 AM
How do you officially determine if your car has the ZO7 package?
thanks much
:cheers:
Apr 3, 2002 | 12:15 AM
Re: Identifying a ZO7 corvette????????? (91 L-9ate)
an RPO code
Apr 3, 2002 | 12:17 AM
Re: Identifying a ZO7 corvette????????? (vader86)
Look at the list of RPO codes on the bottom of your center console. :)
Apr 3, 2002 | 03:11 AM
Re: Identifying a ZO7 corvette????????? (scorp508)
Isn't that the MTI motor? I didn't think that was a dealer installed option, so it wouldn't have an RPO code.
Apr 3, 2002 | 03:29 AM
From: No more yankee my wankee, the Donger is tired!
Re: Identifying a ZO7 corvette????????? (BAdAzZV8)
Yes the Z07 is the MTI motor for the LS6
It was a heavy duty suspension used in the C4's whe nthe Z51 died out. Great for autocrossers.
Apr 4, 2002 | 02:05 AM
Re: Identifying a ZO7 corvette????????? (Jeffvette)
So what does the Z07 vette have that makes it special(please list all parts).
Apr 4, 2002 | 02:17 AM
Z07 was the performance suspension from 91 to 95.
It was the same as 2 previous Z51 years' set up but included FX3 as well in 91.
As the years went on, it got weaker springs and smaller sway bars.
Apr 4, 2002 | 02:39 AM
Re: Identifying a ZO7 corvette????????? (White Lightning 89)
OIC, thanks man.
Apr 4, 2002 | 12:38 PM
If the build sticker is missing from the inside of the center console you can identify a Z07 in the following manner:
-Measure the front brake rotors; Z07's will have 13" rotors with the big calipers.
-Measure the sway bars. Z07's use a 30mm front and a 26mm rear.
-Jeb Burnett
