VATS Module question
you can see the list of other things that can be deleted or changed at the same time to suit what you are doing with the engine.
Dave
Thanks for that info... I always wanted to do some prom programming!
Looks like my choices are TunerCat or Moates?
My situation is that I would like a package deal to do both style OBD1 ecms: TPI MEMCALS and my old 88-90's Chevy trucks with TBI & 1227747 ecms.
Ed
Moates for the hardware ( chip programmer and adapter for chip )
http://www.moates.net/burn2-chip-pro....html?cPath=31
http://www.moates.net/gp1-package-gm....html?cPath=31
TunerPro or TunerCat for the software
http://www.tunerpro.net/
TunerPro has def files for most GM ECM's with removable memcals
http://www.tunerpro.net/downloadBinDefs.htm
You also need a cable to connect your laptop if you want to datalog
http://www.aldlcable.com/
So as you suggested..Moates for the hardware and TunerPro for the software.
