Broken Pawl Rod Clip
Old Oct 28, 2010 | 04:33 PM
me3034's Avatar
me3034
1st Gear
Default Broken Pawl Rod Clip
Has anyone had an issue with their door lock malfunctioning due to a broken pawl rod clip? I'm researching this problem, and came across someone whose door locked and refused to open again. They found that this was due to broken clips. I was just curious if this was a common problem among Corvettes. Also, does anyone know what type of polymer the clips could be made of? This information does not seem to be readily available anywhere.
Thanks.
Old Oct 28, 2010 | 05:44 PM
samsonb's Avatar
samsonb
Never had a problem with the doors. I've read of people having problems with the plastic clip breaking for the blend door on the A/C heat.
Though, those clips can break at any time since they are plastic and they are old. If you have the door panel tore into. It would be a good idea to replace them. You can get them from the dealer.
Old Oct 28, 2010 | 05:47 PM
Rob31's Avatar
Rob31
What year ?? On my 86 the clip just came undone
PINA to get to but an easy fix .Bet the clip is still there & the rod just popped out .
To Broken Pawl Rod Clip
