Do your courtesy lights work? I just went through this on my 84 and the fuse for the courtesy lights also powers the door locks. Don't know if that's the case on your 90, but worth looking at.
Could be door lock switches,door lock actuators,burnt fuse(s),door lock relay if it has one,or wiring problem.Are both door locks inoperative when using either one-driver & passenger?Hearing any noise when pressing door lock switch from either side?When did they stop working?Nice these questions answered to proceed
Both power door locks (passenger and driver) are inop. There is no noise when I press the switch on either door. As far as when they stopped working... I have no clue, they were inoperative when I purchased the car last week.
just another comment from experience...when I bought my 85, I was told that there was a battery drain in that circuit, so the owner pulled the fuse (actually it is a mini circuit breaker in the 85). Turns out there was a short in one of the sport seat toggle switches (same circuit) and when I replaced the shorted out toggle switch, everything worked including power door locks and no more battery drain.
How do I know if I have a small batter drain? I have checked the fuses and all seems good. I have yet to check the relays.
Okay so I replaced the relay and the fuse in the aux fuse box. When I use the power door lock switch on the drivers side everything works. Both drivers and passengers side door locks actuate. When I use the passenger side switch it blows the fuse in the aux fuse box... So it is clear to me it is not the actuator, what else could it be?
It could be a problem in the passenger's side switch,
or a short to ground in the wires from passenger's side
switch to the driver's side switch. Does the fuse blow
on both lock and unlock on the passenger's side?
I got a similar problem..i hear a noise in the passenger side dash when i push both outside and inside door openers. is that a bad fuse then? also, widows and locks dont work
