spark plug gap
Old Oct 29, 2010 | 11:11 AM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
Default spark plug gap
replacing the plugs in 93 lt1 corvette and the NKG IX plugs are gapped at .055 my book says .050 will this be any problem because NKG is recommending not to change the gap.
Old Oct 29, 2010 | 11:23 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I go by the FSM. Not all plugs come gapped properly. The NGKs I took out had a smaller gap than what was recommended.
Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability
in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think.
Old Oct 29, 2010 | 10:40 PM
higgyburners
OK, but would .005" make that much difference, the plugs have a really small diameter electrode on the iridium plugs and i did not want to chance breaking it, if the .005" is not that critical. thanks for your help.
Old Oct 30, 2010 | 10:26 AM
Keystring's Avatar
Keystring
Got one of these?
That hole in the middle is there so you can bend the tip without breaking it.
To spark plug gap
