Another build by PeteK
Old Oct 29, 2010 | 09:45 PM
qws's Avatar
qws
Default Another build by PeteK
Getting a bit excited about this swap. Getting very close to getting it. Figured I'd share some of the pics with you guys I have so far. Not real sure on the specs of everything but its a 383 bored 60 over.
I'm using the heads I already have and will still be using the HSR intake.
I also finished up my dual exhaust a couple of weeks ago. I went with a LT1 3 in stainless steel, so she'll be able to breathe.
Never did a engine swap before and looking forward to it.
Old Oct 29, 2010 | 10:54 PM
esham's Avatar
esham
Old Oct 30, 2010 | 07:46 AM
mseven's Avatar
mseven
sounds like you can't wait...now you will be able to do all the little stuff (more projects) that you don't like while you're in there, it should be good.
Old Oct 30, 2010 | 08:22 AM
Aurora40's Avatar
Aurora40
Originally Posted by qws
You might be giving up some horsepower with that cam!
Sounds like fun.
Old Oct 30, 2010 | 08:43 AM
WW7's Avatar
WW7
Ed, If Im not mistaken thats the (Pet block) that Pete never wanted to sell. It was tested and found to have plenty of metel left after the 60 overbore and he wanted to keep it for a project..Your a lucky man.. If it turns out like my motor did from Pete (and Im sure it will) you will be very happy with the final outcome..Trust Me, he builds great motors....Hope we can see it at Carisle next year...WW
Old Oct 30, 2010 | 08:47 AM
Pete K's Avatar
Pete K
Sounds like fun.
It is an emissions build
Old Oct 30, 2010 | 08:54 AM
WW7's Avatar
WW7
Hey Pete,
What will his final cubic inchs end up being with 60 over? ...WW
Old Oct 30, 2010 | 09:02 AM
Pete K's Avatar
Pete K
Originally Posted by WW7
Hey Pete,
It will be a 388.
His cam will hopefully come in next week. It is gonna be a "perfect" grind, in my opinion.
Old Oct 30, 2010 | 09:13 AM
mtwoolford's Avatar
mtwoolford
did the block need a .060 overbore to clean up ? could it have been cleaned up with less ?
Old Oct 30, 2010 | 09:17 AM
Pete K's Avatar
Pete K
It needed to go .060, as the previous .040 bore had approx .004 taper. This occurred from 10 years of street/strip duty.
Old Oct 30, 2010 | 09:47 AM
qws's Avatar
qws
I've got plans to clean up a lot in there Mick. A lot of little fittings I don't like for the vac set ups and a few parts are getting sent out for powder coating.
Pete, I assume you got the box I sent?
Old Oct 30, 2010 | 09:50 AM
Pete K's Avatar
Pete K
10-4. I didn't open it yet to inspect, but will today or tomorrow. Box was intect, so thats a good sign.
Old Oct 30, 2010 | 10:50 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Yep, I deal with that issue/problem. Pete, are you making it a 4 main?
cumbercr's Avatar
cumbercr
So what cam grind will you use for this emissions motor?
Old Oct 30, 2010 | 10:52 AM
Pete K's Avatar
Pete K
Nope. This is a studded 2 bolt main, and will stay that way. Ed does not plan to make a ton of power, or spin it very high. I was likely way more abusive to this block than Ed will ever be, so he should be ok.
Old Oct 30, 2010 | 10:53 AM
Pete K's Avatar
Pete K
Custom grind hydraulic roller cam, spec'd by me.
I will let Ed post specifics.
The emissions part was a joke. This build did not factor in emissions at all.
Old Oct 30, 2010 | 11:17 AM
qws's Avatar
qws
No need for me to worry about a "emissions" test here. Car is to old so they only go after the basics. Lights/horn works so it passes..
Pete you can post the specs if you want I don't really know them off hand.
I've put all my trust in Pete and know it will be a awesome build in the end. I use one of his convertors as well an its top notch!
Petes gotta get some stickers made cause in the end it will be a ride built by petek motorsports...
I want to get in on the dyno as soon as its all set to get some numbers but i've had issues with the dyno operators in my area. We have 2 here. One is Redline and I used to be able to get on there quite easily but now is a different story. Then there is another new one close by but he's had is own issues. So hopefully by the time this is done his will be ready.
To Another build by PeteK
Old Oct 30, 2010 | 11:35 AM
ch@0s's Avatar
ch@0s
I envy you Ed
Old Oct 30, 2010 | 12:52 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Originally Posted by ch@0s
I envy you Ed
Me too. If it weren't for this ocean between us, I'd be getting a PeteK motor too.
Old Oct 30, 2010 | 01:45 PM
STL94LT1's Avatar
STL94LT1
I feel like school is back in session, engine building 201.
