1993 head light stays up
Old Oct 29, 2010 | 11:31 PM
Applied's Avatar
Applied
Cruising
Default 1993 head light stays up
I have a 93 C4 that when you have the head lights turned on for a while and then turn them off the drivers side head light will not go down. If you let it sit for 15 min or so and turn them on and then off the light closes right up as it should. Any ideas????
Old Oct 30, 2010 | 06:33 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Check for a good connection / tightness of the headlight actuator connector at the headlight. Also find out whether there are 2 or 3 wires at the connector. If there are only 2 wires then the control system is solid state rather than relays. That could be the problem.
