Help !
Old Oct 31, 2010 | 07:30 PM
Joe's Avatar
Joe
Default Help !
Well We are chasing a ghost , started with a miss and back firing at high speed !
New cap, rotor, coil, map sensor, and heat sensor, did not fix the problem !
No codes
Yesterday on a test drive the battery light came on and the gauge showed no charging , took the almost new altinator in for a replacment and it showed to be good , then had them check the battery also good !
Put the battery back in this morning all is working but the miss & back firing are still there , thinking the fuel pump , any ideas ??
Old Oct 31, 2010 | 07:36 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
back fire is sometimes caused by lean fuel conditions.
Old Oct 31, 2010 | 08:14 PM
383vett's Avatar
383vett
Try changing plugs.
Old Oct 31, 2010 | 08:28 PM
JackDidley's Avatar
JackDidley
Check fuel pressure and check for codes.
Old Oct 31, 2010 | 09:14 PM
hooked073's Avatar
hooked073
Plug Wires?
Old Oct 31, 2010 | 09:52 PM
Joe's Avatar
Joe
Black smoke coming out of side pipes , think it is dumping to much fuel , sure it needs new plugs but would like to cure problem first , might need wires to, but have high dollar ones on it , high heat for the headers !
To Help !
