Bent Intake valve
Old Nov 4, 2010 | 08:50 PM
kc1234's Avatar
kc1234
Default Bent Intake valve
What would cause a bent intake valve on a LT4? Engine was rebuilt 6000 miles ago and has run perfect with out any issues. Heads were checked at time of rebuild, decked and a valve job was done. Engine has not been abused or driven hard. Any ideas would be appreciated.
Old Nov 4, 2010 | 09:43 PM
AVL94LT1383's Avatar
AVL94LT1383
what is the lift on the cam?
Old Nov 4, 2010 | 09:44 PM
AVL94LT1383
did they change the rocker ratio?
Old Nov 4, 2010 | 10:00 PM
THE 383 admiral's Avatar
THE 383 admiral
were the springs tested for PSI & coil bind
and set to the correct height
Old Nov 4, 2010 | 10:11 PM
kc1234's Avatar
kc1234
It is a completely stock LT4, no mods and springs etc were tested.
Old Nov 5, 2010 | 11:34 AM
THE 383 admiral
the only explanation is a worn valve guide or over REV
but you state the heads were checked <> and no abuse..
did you over tighten the rockers ?????
this is the only 2 options left......
To Bent Intake valve
