Working on my 1993 6 speed.Fresh engine.Ported the heads, LT4 hot cam, 1.6 roller rockers. Idles bad, original chip.
Where is the knock sensor module, of course I know where the sensors on the block are, I put them in. I heard putting in a LT4 module in will help.I believe on a 1996 LT4 the module is in the ECU.In 93 is isn't.
Anybody ran across this problems before. Thanks so much for any help
Where is the knock sensor module, of course I know where the sensors on the block are,.I believe on a 1996 LT4 the module is in the ECU.In 93 is isn't.
93 ECM has a chip ( memcal ), KS module is part of the electronics in the chip and not removable; not a plug in unit like on the later alum case PCM's
If you need KS adjustments ( desensitize ) it has to be done in the tune
Pulled the codes or done any data logging ?
