Synthetic Automatic Transmission Fluid (ATF)
Old Nov 6, 2010 | 01:21 PM
Marv02's Avatar
Marv02
Default Synthetic Automatic Transmission Fluid (ATF)
I getting ready to buy some ATF for my newly rebuilt 700r4 what type of ATF should I use.
I been thinking of buying AMSOIL Synthetic Automatic Transmission Fluid (ATF) $130.00 but is it worth the extra money or just get the standered stuff.
Is Walmart stuff for $50.00 good enough.
I read All standered ATF should be made the same.
Cheeper would be better but I know sometimes it better to spend the money than go cheep.
Old Nov 6, 2010 | 01:29 PM
tblt44's Avatar
tblt44
I use Mobile 1 atf but put valvoline max life in the vette
Old Nov 6, 2010 | 01:48 PM
Marv02's Avatar
Marv02
What I have gathered Full Syn last longer and runs cooler.
I know cooler the trans longer it last per the ATF Manufactures.
But in real life is Full Syn worth the extra money or just change out the standered stuff with new filter out every 30000 miles is better for the trans.
Mobil 1 is good stuff but the same price is AMSOIL.
I use Valvoline VR1 Racing oil in the motor for the Zinc I am using a Flat tapped Hyd cam.
Old Nov 6, 2010 | 02:54 PM
Aurora40's Avatar
Aurora40
FYI, regular GM Dexron VI is synthetic.
Old Nov 6, 2010 | 05:16 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I use Mobil 1 Syn ATF
Old Nov 7, 2010 | 01:05 AM
mrbillybob's Avatar
mrbillybob
Default trans fluid
Have you considered adding a transcooler (B&M or Hayden)With a good quality synthetic and cooler temps ,the fluid will last longer, so the added cost is negligible. Also a neodymium magnet epoxied to the pan or magnetic drain plug will help keep small particles of metal on the bottom of the pan.
Old Nov 7, 2010 | 01:56 AM
383vett's Avatar
383vett
FYI, stock 700r4 and 4l60e tansmissions have magnets placed inside the bottom of the pan. They don't need to be epoxied because they stick to the metal pan. There is an indentation in the pan bottom to locate the magnet.
Old Nov 7, 2010 | 09:27 AM
Marv02's Avatar
Marv02
I going to use GM Dexron VI it the best deal so far.
I have a 18000 GVW trans cooler installed now so it should bew fine.
Thanks everyone for the input.
Old Nov 7, 2010 | 02:35 PM
mrbillybob's Avatar
mrbillybob
Thanks for the information,can you imagine, engineers doing something an amateur thinks about? Makes one re-think some of the value of some of the modifications that are available on todays market.
Old Nov 7, 2010 | 02:40 PM
mrbillybob's Avatar
mrbillybob
Where did you install cooler. With the BTU's mentioned the cooler must be close 11 x7 x 1 1/2 inches. If installed in front of A/C condenser, did it cut down on air flow and raise coolant temperature?Thanks in advance.
Old Nov 7, 2010 | 02:54 PM
Marv02's Avatar
Marv02
I running the Trans cooler in front side of the right side of the rad and a Engine oil cooler on the left side of the rad so far I dont have any over heating issues.
The engine oil runs about 170 when the Water temp gets to 220 before the fans kick on this is sitting still with no air flow going though the Rad.
Old Nov 7, 2010 | 10:17 PM
steverichmond's Avatar
steverichmond
I planning on replacing my tranmission filter. It's a stock 93 LT1 with 63,000 miles on it. Would I be ok refilling with GM Dexron VI?
Thanks,
Steve
Old Nov 7, 2010 | 10:45 PM
MrRenoman's Avatar
MrRenoman
I used Amsoil in my trans. Search for Subdriver on this forum. He a sponser and a distributor. I was shipped a gallon of synthetic trans fluid, 2 qts of synthetic differential fluid, and the pump for around $76 shipped to my house. I know he'll give a great deal and you'll be happy with Amsoil, I am.
Art
Old Nov 8, 2010 | 10:20 AM
383vett's Avatar
383vett
Art
A gallon of synthetic is less than half the capacity of the tranny. I guess it's ok to mix?
To Synthetic Automatic Transmission Fluid (ATF)
