Even after reading the FAQ on C4 audio install, I'm still unclear on where to tap into the Bose system in my 96 coupe.
I'm installing a powered sub in the rear and would like to tap the wiring in the rear-mounted factory amp for the left and right channels, but am unsure what wires carry the processed signals.
I wondered about that to so when I called dr. dons about repairing my factory deck I asked him about wiring a sub to stock system also. It was a long time ago but he said something about the stock Bose wiring being different ohm type and you had to wire in a resister on sub's wiring or you would burn the sub up. Maybe you should call him directly, he could tell you very easily how to wire it. Good Luck Tim
I was thinking of doing the same thing. The stock Bose is a one ohm system. But I think the inputs come into the amps at "line level" and a line level adapter to a POWERED sub should work and what I had planned to do.
