Just bought my first corvette. It's a project car. Brought it home today and tried to start but it won't crank. This is what happens turn it on radiator fans engage the check gauges light is on the door ajar service engine soon and service abs. The speedometer doesn't turn on and when I crank it the brake light comes on. Dunno what the problem is? Any help would be great.
Nevermind, just read it all. First things first, are you getting spark and fuel? Quick way to check for fuel is try to crank it for a second or two, then pull the easiest spark plug. If its wet or reaks of fuel, you're propbably good there. To check for spark, take that spark plug, stick the wire on the end of it and rest it somewhere really close to metal like a ground bolt. When I say close, I mean close, but not touching. Have someone try to crank the car while you're looking at the spark plug. See if there is any spark.
These are quick and easy to me, but might not be for you. If not, get a scan tool of some sort.
Is the battery charged? If so try a known good battery it could be shorted.
If battery is OK, check your fusable links, grounding strap, see if you can turn the engine with a breaker bar connected to the crank bolt to see if it seized, could be a bad starter. Can you hear the solonoid engage the starter, a click/light thunk sound when turning the key?
Is the security light lit with no click? If so it is VATs. Vats is a security thing that reads the value of a resister built into the key. After a while it can go bad producing the wrong value and the car thinks your trying to steal it.
You have very serious wiring problems and you should try fixing these problems one at a time. Start with the starter motor. Buy a GM service manual including the electrical diagnosis manual, they are very good books, especially the electrical diagnosis manual. Follow the troubleshooting instructions in the electrical book. Come back here and ask questions and include what you have done.
