94 LT1 erratic idle
Old Nov 11, 2010 | 09:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default 94 LT1 erratic idle
what can cause this. when I put it in neutral the engine will run smooth but while in gear it will not run smooth. I replace the MAF 2 months ago and it went away but now its back. is there anther sensor to look at.
Old Nov 12, 2010 | 05:13 PM
screamin_conure's Avatar
screamin_conure
Erratic idle can be any number of things, especially on an LT1. The most common cause though, is usually a dirty idle air controller valve. The IAC is installed on the lower, passenger side of the throttle body below the TB blades. Just carefully remove the 4-wire electrical connector that plugs into it, remove the rubber air coupler that connects the air filter box to the face of the TB, and unscrew the IAC from its housing. Clean the tip of it with a clean cloth that is sprayed with a bit of throttle body cleaner. You can also shoot a bit of TB cleaner into the IAC opening and wipe that out with a rag. Put everything back and see how she runs.
Is your problem only with idle? How does the car run under acceleration?
Old Nov 12, 2010 | 05:28 PM
Nowhere Man
under hard acceleration it wants to stumble. I will try that on sat and hopefully it will help or fix the problem
Old Nov 12, 2010 | 05:32 PM
screamin_conure
If you're having some issues under acceleration, it might not be the IAC but I'd still go ahead and clean it. I'd also check fuel pressure and also pull a couple of plugs and see how they're looking.
Old Nov 12, 2010 | 11:55 PM
Nowhere Man
I went ahead and replaced the IAC sensor it was only 15 bucks. that seemed to help the idle so now it idle smooths but it still has a stumble on acceleration. I can rev it up fine when not in gear. its when its under load it stumbles. so I am going to see if I can barrow a fuel pressure gauge and see what it reads.
Old Nov 13, 2010 | 12:02 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Check the ohms of the injectors with a digital volt-meter. If on or more are off compared to the others, that may be the culprit.
Old Nov 13, 2010 | 08:56 AM
94vettelover2's Avatar
94vettelover2
Heres a test to see if engine is misfiring.Have someone get in car,start it,& put it in drive.While engine is running(but running poorly like you previously stated) dissconnect each injector,one at a time until no change in idle speed or change in stumble is felt.The engine may die even with 1 injector disconnected.Restart & try again.Once you found the affected cylinder(no change in the way engine runs or any change in idle speed is felt/noticed),you can check that cylinders injector,spark plug,spark plug wire,& compression.The above test only works with engine in drive-with someone helping you.Let me/us know after you do above test
Old Nov 13, 2010 | 04:14 PM
McGirk94LT1's Avatar
McGirk94LT1
Very interested in your outcome. I have the EXACT same problem. If its acting up, put it in neutral it revs a second then idles fine. But under certain levels of acceleration and if its lugging low rpms it misses. Sure hope you find your solution.
Old Nov 13, 2010 | 04:43 PM
desertmike1's Avatar
desertmike1
I had this same problem, it turned out to be a plug boot that was not fully engaged, when I removed it I found white powder build up inside of it, were it was arching.
I think I over greased it when I replaced the plug wires two years ago.
now there are many things that can cause a miss or hesitation, this turned out to be my problem.
Alcohol wipe and new silicone grease (lightly) cured the problem.
Old Nov 13, 2010 | 07:33 PM
Nowhere Man
I talked to a friend that wrenches on cars and told me to replace the MAF. I did that a few months ago and it ran fine then it started to act up again. so I went back to were I got it and got me another one. so it now runs fine. so I am hoping this last longer then the last time
Old Nov 14, 2010 | 10:56 AM
Nowhere Man
put the new rebuilt maf on the car. the car ran great for a while then right back to were it was. would the ECM be on its way out?
Old Nov 14, 2010 | 03:37 PM
hgh pwr's Avatar
hgh pwr
When my lt1 was not idleing good I was told to clean the iac motor,which didn't help and the problem turned out to be the tps,replaced it and all was good.Check your sensor for the 5 volts and see if its good.Good luck
Old Nov 14, 2010 | 03:55 PM
Nowhere Man
TPS throttle position sensor. now where were is that.
Old Nov 14, 2010 | 05:29 PM
desertmike1
What exactly do you meen by "Erratic" try to give a little bit more info..
Old Nov 14, 2010 | 06:56 PM
Nowhere Man
that part was fixed with the IAC. but what I did mean was it would not idle smooth it would jump from 500 to 800 rpm
Old Nov 14, 2010 | 07:33 PM
desertmike1
I think I understand!
Have you looked around for Vacuum leak, this could cause idling issues.
Old Nov 14, 2010 | 07:40 PM
Nowhere Man
no that I have not. but like I said it seems to idle smooth now. its just now when the motor is under load while driving it wants to break up or stumble around 1200 rpm. a new rebuilt MAF fixed the problem for about 10 miles then all of a sudden it went back to they way it ran before. that part I do not understand
Old Nov 14, 2010 | 08:19 PM
desertmike1
This break down under load, is exatly what I chased...in my case it turned out to be a simple loose plug lead. I also had an idle issue.
How many Miles on the ignition system since it was last serviced?
Re-check the connector for the MAF, there might be some corrosion, at the connectors, you really need to use a magnifire glass to get an up close look.
I actually put up with my problem for quite some time before I got it fixed. I understand the frustration!!
Old Nov 14, 2010 | 08:52 PM
Nowhere Man
I replaced the opti, wires, and plugs around 20K miles ago. I have been chasing this problem for a while too. its seems every time I work at it the problem just to come back and I just have to walk away from it before I kill it
To 94 LT1 erratic idle
