Rear hub squeal
Old Nov 12, 2010 | 04:37 AM
samsonb's Avatar
samsonb
Default Rear hub squeal
Looks like the squeal is from the dust seal not getting lubbed when the hub was put togther.
Old Nov 12, 2010 | 07:57 AM
Brian Smith's Avatar
Brian Smith
On my 1993 the torque was only 164 ft. lbs. Did the manual call for all 185? Maybe it was excessive and hurt the little feller.
Old Nov 12, 2010 | 08:10 AM
WW7's Avatar
WW7
The torque rating was revised up to 182-192 ft lbs in a update to the manual. His torque is fine.....WW
Old Nov 12, 2010 | 08:51 AM
HlhnEast's Avatar
HlhnEast
Hey Josh, I cant seem to get the link to work. I am interested in this as I too have a squeal in the rear. Mine occurs after the car has been driven for about an hour at highway speeds. After I stop, then take off, particularly when making a left turn I get a grinding squeal coming from the left rear. I am thinking either new teflon washers (or lack of) or change the dif lube with posi additive. I had the hubs changed about 8-10K miles ago.
Kinda like I will get to it one of these days but that day hasnt come yet.
Old Nov 12, 2010 | 02:25 PM
Charleston2012's Avatar
Charleston2012
Is this torque rating for all C4's?
Old Nov 12, 2010 | 07:39 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Did you try rotating the half shaft to give you a better shot at the bolt?
I've had them off my 92 a couple of times. Didn't use any locktite when I reassembled.
Good luck!
Old Nov 13, 2010 | 02:36 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by joshwilson3
When I put those bolts back in, I may not put any blue thread lock on.
Best lessons learned are those by mistake.
Old Nov 13, 2010 | 05:19 AM
EPF's Avatar
EPF
Josh,
I had the same problem with the top bolt. I gave up and took the whole knuckle off. Maybe I didn't need to, but it sure made easy work of getting the torx bolts out on the bench.
Old Nov 13, 2010 | 03:39 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Did you put any thread lock on the ujoint strap bolts?
Yep, a drop of blue thread lock on those bolts.
Old Nov 14, 2010 | 12:55 PM
M. Schumacher's Avatar
M. Schumacher
Originally Posted by EPF
Josh,
At that point it doesn't take much more to remove the knuckle. Of course, then you're going to want to replace the bushings. And while you're in there....
To Rear hub squeal
