mis-fire codes
Old Nov 12, 2010 | 08:37 AM
crmvette's Avatar
crmvette
Default mis-fire codes
replaced dual mass flywheel with steel single mass,noisey and vibrates as expected. now seems to be setting mis-fire code any one else have this issue-could they be related. thanks for any input.
Rick
Old Nov 19, 2010 | 03:32 PM
crmvette's Avatar
crmvette
Default confused
Rick
dont understand this forum. have heard nice things about this group seems when ever i ask a question i get no or very few respones. is me or how i put the the out there---just wondering
Old Nov 19, 2010 | 03:56 PM
sailorsteve's Avatar
sailorsteve
What year is your car?
What do you mean by "mis-fire code"? Do you have a code number?
Old Nov 19, 2010 | 04:03 PM
Sargevette's Avatar
Sargevette
Knock sensors?
Old Nov 20, 2010 | 08:40 AM
crmvette's Avatar
crmvette
Originally Posted by Sargevette
Knock sensors?
it is a 96 and intermittenly sets a p0300 will clear itself. just wondering if related to flywheel change
Old Nov 20, 2010 | 09:23 AM
sailorsteve
The '96 is a hybrid OBD1-OBD2 diagnostic system. Not familiar with it, but I think that code is set when a slight variation in crank speed is detected, as would be the case with a misfire. I could picture that code being set off by the sm flywheel, as the trans rattle would then be directly relayed to the engine. (Just a guess- you didn't hear it from me)
Old Nov 20, 2010 | 09:45 AM
crmvette's Avatar
crmvette
thanks sailorsteve,makes sense,was just wondering if other owners had same issue(no---didn't hear it from you)
Old Nov 20, 2010 | 10:09 AM
jeffp1167's Avatar
jeffp1167
I have a 97 Camaro that has had mis-fire detected but not sure if it is even close to the "hybrid" obd1-2 system. But in order for it to have that kind of code set there has to be a resistance change in the spark plug circuit .. plug wires/coils/plugs. A rattle won't cause it, I would be more inclined to say the knock sensor is hearing it.
My misfire detected was from a plug wire that was blistered and brittle. My 3.8 has a great deal of engine related noises but only time misfire detected was plug wire related.
good luck
Old Nov 20, 2010 | 04:23 PM
94vettelover2's Avatar
94vettelover2
If the problem happened after the work-its 99% of the time from the install.That 1% is coincidence.My guess would be a knock sensor as their sensing knock then adjusting computer & computer reads as a slight misfire.I've read too many problems(here) when not sticking to the dual mass flywheel to not ever recommend installing anything else even though expensive.I wouldn't keep driving the car & don't ignore this problem.Keep us updated on what you find
Old Nov 20, 2010 | 04:29 PM
STL94LT1's Avatar
STL94LT1
1996 was pure OBDII, no hybrid.
Old Nov 20, 2010 | 05:04 PM
Bronze85's Avatar
Bronze85
First year for OBD II for Fed. Emmisions.
Old Nov 20, 2010 | 08:48 PM
sailorsteve
But I was under the impression that the '96 still uses the old-style ALDL connector and that there are some other slight differences in the diagnostics. Is this not the case?
Old Nov 20, 2010 | 09:04 PM
STL94LT1's Avatar
STL94LT1
sailorsteve, 94/95 uses an OBDI PCM with an OBDII ALDL. Maybe this is what you are thinking about.
Old Nov 20, 2010 | 09:06 PM
sailorsteve
Thanks for the info. I'm always the last one to find out about anything.
Old Nov 20, 2010 | 10:06 PM
hooked073's Avatar
hooked073
that code is set when there is like a 3% difference in RPM's at set points. Lets say at a steady 1500 if between the firing of one cyl to the next is more then 3% it will set a code. The bad part is untill latter years was tech good enough to idenify what cyl it was coming from. Jeff the ECM does not measure resistance change in the wires,plugs ect. I am sure what happened with your car was it had a miss from a bad plug wire that missed was picked up by a difference in the RPM's. To the PO I do not think the noise would cause what you are expericing but it may be possible that you new flywheel is not balanced right and causing a RPM veraince. But I would be sure you do not have a slight miss.
To mis-fire codes
