stop lites dont work?????
Old Nov 12, 2010 | 06:40 PM
SEAFOUR's Avatar
SEAFOUR
Default stop lites dont work?????
IM WONDERING IF THIS IS COMMON TO 85VETTES! I checked power to and from brake lite switch and emerg flashers work ,blinkers ,parklites also work. Stop lites were working. WTF?
Old Nov 12, 2010 | 06:53 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Has the fuse been checked?
Old Nov 12, 2010 | 07:33 PM
SEAFOUR's Avatar
SEAFOUR
Yes fuse is good
Old Nov 12, 2010 | 09:34 PM
vetteoz's Avatar
vetteoz
Hazards which are working use same fuse as stop
As those lights are working and you have power out of brake switch then only thing left is the column switch mech itself
Old Nov 12, 2010 | 10:03 PM
ex-x-fire's Avatar
ex-x-fire
Try stepping on the brakes while wiggling the turn signal switch, have someone watch the brake lights.
Old Nov 12, 2010 | 10:31 PM
tpi 421 vette's Avatar
tpi 421 vette
It goes from the brake light switch thur the turn signal switch. I would bet the turn signal switch is your problem. It wouldn't be the first time I have seen a bad turn signal switch make the brake lights not work.
Old Nov 14, 2010 | 04:53 PM
SEAFOUR's Avatar
SEAFOUR
WOW!! You guys are good! Thanks vetteoz, that w/diagram made it easy.You nailed it!! It was the white wire in the turn signal switch plug at the steering column. I had no stoplites for awhile and it was really buggin me. GOT THEM NOW. Thanks again, Tom
To stop lites dont work?????
