Still having a problem , jump on it and takes off like a rapped ape , gets up to 2000 rpms and shuts down !
I have installed a new fuel pump , fuel filter checked the pressure and is good .
New map sensor , New temp sensor, checked the coil , good . I have a new pickup coil to put in tomorrow , only other thing I can think of is the ECM could be messing up !?
Any one got any ideas ?
Did you check for codes? A bad ECM will throw a code. Good luck
Mike
