Which plug wire separators are you using?
Old Apr 4, 2002 | 04:24 PM
gpagaduan's Avatar
gpagaduan
Default Which plug wire separators are you using?
Got Pics? I like the Made For You brand in Summit Racing's catalog. $42 for plastic!!!????!!! But they mount to the center bolts on the valve covers and look pretty clean.
Old Apr 4, 2002 | 04:38 PM
J Z06's Avatar
J Z06
Default Re: Which plug wire separators are you using? (gpagaduan)
Moroso! Ordered from Summit. They look nice.
Old Apr 4, 2002 | 05:33 PM
Lone Ranger's Avatar
Lone Ranger
Get good ones. One of the wire brackets the dealer service dept. shop put on my '95 came loose and let enough slack for the #5, #7 wires touch the exhaust manifold :eek: :mad
Old Apr 4, 2002 | 05:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The IROC LB9 has vettical perimimeter bolt Made For You's with MSD 8.5mm wires; the Vette uses stock separaters with TPIS wires.
The Made For You can be had in vertical or horizontal for center or perimeter bolt covers.
Old Apr 4, 2002 | 06:22 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm using the stock ones.
Old Apr 4, 2002 | 07:28 PM
ezmoney92's Avatar
ezmoney92
Default Re: Which plug wire separators are you using? (mackeyred96)
I use the stock separators and they hold the Magnecor 8.5's fine. :seeya
Old Apr 4, 2002 | 09:45 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: Which plug wire separators are you using? (ezmoney92)
You don't have to spend $50 on the centerbolt separators. Just buy the made-for-you products universal kit, much cheaper.
To Which plug wire separators are you using?
