how long does it take to change shocks?
Old Apr 4, 2002 | 07:30 PM
Wheelman's Avatar
Wheelman
Default how long does it take to change shocks?
and how hard is it?
thanks
Old Apr 4, 2002 | 07:33 PM
bogus's Avatar
bogus
Default Re: how long does it take to change shocks? (C4Fetish)
not very long.
not very hard.
expect and hour... it will go better if you have an impact wrench. Also, spray some PB Blaster or equivilent in advance.
Old Apr 4, 2002 | 08:42 PM
Dan Parker '96's Avatar
Dan Parker '96
Cake... 1.5 hours to pop your cherry on it.
Old Apr 4, 2002 | 09:22 PM
Rich B.'s Avatar
Rich B.
Default Re: how long does it take to change shocks? (Dan Parker '96)
I estimate it took me 2 1/2 hours...Most of it was the jacking...(all 4 shocks)...
Pretty easy...Rear required wheel removal; fronts didn't...(For me, anyway)...
Jacking and finding correct size metric sockets was the time-killer... :crazy:
Old Apr 4, 2002 | 09:25 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
The time it takes to read this post you would be done.
Old Apr 4, 2002 | 10:43 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: how long does it take to change shocks? (mackeyred96)
Over-torqueing and breaking one of the 8mm bolts that holds the rear tower plate to the frame was my big hang-up.
Rears are dead easy. I haven't tried fronts yet.
Old Apr 5, 2002 | 01:29 AM
jvesalga's Avatar
jvesalga
About a week. Make sure you have 2 kegs of beer, one good friend and call the hooters girls over. Then it does not sem so bad.
15 minutes a shock.............but the girls are into fetish, however not the c4 type.
joe
Old Apr 5, 2002 | 02:38 PM
L-98Vette91's Avatar
L-98Vette91
Cruising
Default Re: how long does it take to change shocks? (jvesalga)
I did this last weekend on the '91. Fronts were a piece of cake. Took a little time because I was also cleaning up the upper and lower A-Arms while I was in there. I get to the left rear and couldn't get the shock off the lower mount. Tried my hardest, it wouldn't come off. Finally just unbolted the lower mount and took the whole thing off. Pulled out the hacksaw and cut throught the metal and bushing. Turned out that the metal cylinder inside the bushing had rusted itself to the lower mount. Get to the right rear thinking it would be the same and the shock almost fell off in my hand. I guess you run into those things working on a 12 year old car. :D :D
Old Apr 5, 2002 | 02:43 PM
ZR_TO_ENA's Avatar
ZR_TO_ENA
Around 2-3 hours all around.
Good Luck
--john
Old Apr 5, 2002 | 04:28 PM
vetluvr's Avatar
vetluvr
St. Jude Donor '08
Default Re: how long does it take to change shocks? (bogus)
not very long.
not very hard.
Rear required wheel removal.
:nono:
No need to remove any wheels.
Old Apr 5, 2002 | 05:12 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: how long does it take to change shocks? (vetluvr)
I take all the wheels off just to make it easier. It does take a little bit longer though. I estimate 2 hours with some cleaning at the same time.
Old Apr 5, 2002 | 11:56 PM
tuband's Avatar
tuband
Cruise-In I Veteran
:lol: :lol: :lol: :lol: :lol: :lol:
Old Apr 8, 2002 | 03:00 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: how long does it take to change shocks? (tuband)
Tossed in 4 KYB's Saturday, took an hour. Wheels on,air tools. Rides nice.:)
Old Apr 8, 2002 | 03:08 PM
Kale's Avatar
Kale
pretty easy. the only remotely difficult part was the back end, but only because the wheels had to come off. :jester Getting the rear suspension clean and shiny wasn't every easy, either! But Flitz made that half shaft shine like chrome!
[Modified by Kale, 1:10 PM 4/8/2002]
Old Apr 8, 2002 | 10:56 PM
R23HTC's Avatar
R23HTC
Default Re: how long does it take to change shocks? (Kale)
I backed mine up onto my ramps. Left the wheels on! :D Took less than an hour for both sides. Save the cleaning for later. :jester
To how long does it take to change shocks?
