Intermittent starter problems, 87' C4
I'm at wits end with the blue one (87' C4). Replaced a starter that had a 'heat soak' problem with the solenoid and am now rewarded with an intermittent starter problem. It is a brand new starter and solenoid. Have removed the starter twice and had it at the shop that rebuilt the starter and it worked perfectly on the bench, multiple times.
Also replaced both battery cables (what an absolute b!tch!), cleaned all the connections as well and the areas where the starter and the grounds connect to the block with degreaser. So it has brand new cables too.
Despite all of this, I get 'click-click' from the solenoid and then a strong start. Sometimes it's one click and a start. Other times, it takes three, four even five tries. Sometimes, it will start, right up on the first try!!!
Any thoughts or help on this would be highly appreciated!
But you said the starter is new but you had it back at the shop that "rebuilt the starter".
So is it a rebuild or brand new from a parts place? Sometimes a rebuild can have other problems internally that the rebuilder can miss or not check.
Next step was to check the voltage from the ignition key (Purple wire) and when it clicked, it was only 6.6 volts. According to the FSM takes at least 7 V to fully engage the solonoid. When it worked, I was getting just a little over 8.6 and sometimes 9, clearly above the minimum to energize the solonoid fully.
The low voltage reading also caused the digital dash to turn darker than normal under cranking conditions.
So it may be either the purple wire (and I replaced the connector on the end) or the ignition switch. The red wire off the solonoid, that is hooked up along with the battery cable goes straight to the ignition switch. When you turn the key all the way, the connection is made between the red wire and the purple wire to energize the solonoid.
I will be checking for 12v INTO the switch with the red wire and 12v out of the switch at the purple wire. If I get the 12v out, then the wire is the culprit and it is a straight hook up to the solonoid. It doesn't go through anything before it gets there to the best of my knowledge. If I don't get the equivalent voltage out, then it's the ignition switch.
The ignition switch and the key cylinder are two different parts and oddly enough, in the FSM, there are only two wires running out of the key cylinder to the ignition switch, but multiple wires running out of the ignition. How do the two wires out of the ignition cylinder create all the multiple conditions in the ignition switch (Acc, Run, Off and Start)?
The key cylinder in this car is pretty worn out and loosey-goosey. Another possibility is one of the wires grounding out inside the steering column.
Any thoughts on the relationship between the ignition key cylinder and the ignition switch module?
PS: Gawd, I hate intermittent problems, but I'm getting closer on this one!
Thanks all!
http://www.joestradingpost.com/vats/index.html
My money is on the clutch safety switch or the start enable relay contacts.
C409, thanks too, for explaining the relationship between the key cylinder and the switch, I will check that as well!
Lesson learned: just because the solonoid is clicking, doesn't mean it's bad. It may not be getting the 7V mininum to actuate completely, but enough to partially engage or 'click'!
The Starter Enable Terminal is at the other end of the yellow and it's getting the same low voltage that's coming out of the Ignition Switch.
Thanks all, for your help with this complex, but frustrating problem!
