My PeteK engine just about ready
Old Nov 21, 2010 | 08:38 AM
  #41
nutz4c4's Avatar
nutz4c4
Originally Posted by Pete K
Installed yet
Gotta go check on that boy today..
Old Nov 21, 2010 | 10:04 AM
  #42
qws's Avatar
qws
Safely made it home with my "package".... I had more power for sure going over those hills!
Awfully nice of you to throw on that fluid damper that you had laying around!....:rofl :
I have to go out an get some heads bolts... accidently threw all my used ones out. Off hand do you know the thread size? Maybe I can just go to the hardware store.
Pete... also came up with a whole bunch of more questions for you.
And yep I'll be posting up some more pics later today!...
Old Nov 21, 2010 | 10:10 AM
  #43
STL94LT1's Avatar
STL94LT1
Hopefully this is a joke?
Old Nov 21, 2010 | 10:28 AM
  #44
WW7's Avatar
WW7
You mean this isn't where you buy yours??? Why pay those high ARP prices when a #8 will do just fine.....WW
Old Nov 21, 2010 | 10:44 AM
  #45
qws's Avatar
qws
I need to get just four bolts and washers to bolt my crane to the shortblock to unload off the truck. Figured if I knew the thread size I'd just go to the store and get 4 #8's rather than buy a whole kit from the auto store.
Old Nov 21, 2010 | 10:46 AM
  #46
mseven's Avatar
mseven
I guess that depends oh where you're thinking of bolting the chain...my guess 3/8 16
Old Nov 21, 2010 | 11:04 AM
  #47
qws's Avatar
qws
My thought was right into the holes for the heads. Naturally I need to put something in between to protect the deck
Old Nov 21, 2010 | 11:11 AM
  #48
WW7's Avatar
WW7
I wouldn't take a chance of screwing up the deck surfaces, I would use front and back holes. Waterpump and trans holes with rags for buffer....WW
Old Nov 21, 2010 | 11:17 AM
  #49
qws's Avatar
qws
Originally Posted by WW7
I wouldn't take a change of screwing up the deck surfaces, I would use front and back holes. Waterpump and trans holes with rags for buffer....WW
That makes more sense to me. Thanks
Wonder what this is?
Old Nov 21, 2010 | 11:24 AM
  #50
mseven's Avatar
mseven
I'd use the water pump holes for at least the front...the rear may have to use a deck hole.
looks good Ed...now strap 'em on, and get a buddy a get over there to help lift it off the back of the truck.
With no heads/intake, it's not that very heavy.
Old Nov 21, 2010 | 11:25 AM
  #51
mseven's Avatar
mseven
uh..aunt edna ?? lol
Old Nov 21, 2010 | 11:29 AM
  #52
WW7's Avatar
WW7
Yea Ed, mine had heads and intake on it and a buddy and myself lifted it off the back of my truck. With no heads or intake you shouldn't have any problem with a friend helping..( How strong is your wife??) ....WW
Old Nov 21, 2010 | 02:16 PM
  #53
STL94LT1's Avatar
STL94LT1
Old Nov 21, 2010 | 02:40 PM
  #54
qws's Avatar
qws
Got in unloaded. Nutz4c4 set me straight when he stopped over. Just connected the leveler to the stand.
BTW a little revision was made to the cam specs
230/236 duration @.050
.603 intake
.608 exhaust
Lobe seperation is 110
Old Nov 21, 2010 | 02:55 PM
  #55
nutz4c4's Avatar
nutz4c4
I still say you should have arm wrestled it off of there or let those two little dogs pull it off
Old Nov 21, 2010 | 04:00 PM
  #56
tehcarguy's Avatar
tehcarguy
Why did you decide to go with a cast rotating assembly and not forged?
Old Nov 25, 2010 | 06:52 PM
  #57
pipe's Avatar
pipe
Soon Pete won't be able to build anymore he's gonna run for the points title in the NED in Super Comp or be a Roadie for the rock band KISS Good Build buddy Pipe
