Replacing 6 speed shifter boot
Old Nov 16, 2010 | 05:20 PM
TSHANNON's Avatar
TSHANNON
Default Replacing 6 speed shifter boot
I have a 1991 with a 6 speed and I'm trying to replace the boot. I'm not sure how to remove the reverse ****. Is it attached to the shaft with an allen setscrew or a roll pin?
Thanks Tim
Old Nov 16, 2010 | 05:34 PM
jimmers's Avatar
jimmers
There is a tiny allen screw (not sure of size) that needs to be loosened for the reverse **** to be removed. If you look at the front there is a little slot. In that slot is the hole for the allen key. Don't loose the screw!
Old Nov 16, 2010 | 05:43 PM
TSHANNON's Avatar
TSHANNON
Thanks tim
Old Nov 16, 2010 | 07:42 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
IIRC, it's' a 1.5mm allen screw. Be careful when you reinstall it. I bet it's fairly easy to strip -- since it's screwed into plastic!!!!
To Replacing 6 speed shifter boot
