How hot should ?
Old Apr 4, 2002 | 11:22 PM
IPRESS's Avatar
IPRESS
Default How hot should ?
How hot should my LT1 get in stop and go traffic or at idle (for several minutes)? Outside Temp about 70 degrees.
Old Apr 4, 2002 | 11:28 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: How hot should ? (IPRESS)
Stock will probably go north of 230*.
If you turn the AC on, the fans will kick in sooner and drop the temp closer to your 180* thermostat.
Doesn't that 230* just bother you!!!!! It's normal, but too high for me!
Old Apr 4, 2002 | 11:32 PM
Blk-94's Avatar
Blk-94
Default Re: How hot should ? (PeteL)
You're kidding.. 230 is normal!!!?? I'm freaking out when it starts going over 205. And having a heart attack at 220. :D
Old Apr 4, 2002 | 11:33 PM
IPRESS's Avatar
IPRESS
Scares the s _ _ _ out of me. Will a lower stat (165) help any?
Old Apr 4, 2002 | 11:36 PM
c4cruiser's Avatar
c4cruiser
I've never seen more that 215-220 or so and that's after 3 or 4 runs on the autocross course! Even track days don't sent temps above that.
But turning on the A/C is the quickest way of dropping the temp!
Old Apr 4, 2002 | 11:43 PM
vader86's Avatar
vader86
Yep, all corvettes run that hot for emissions standards.
Installing a 160 or 180 thermostat and gettin the Hypertech PP to set your fans on earlier will fix it, along with cleaning the front of your radiator.
Old Apr 5, 2002 | 12:44 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: How hot should ? (vader86)
I've seen 230 sitting in 80 degree weather and typical Florida traffic. I just flick on teh A/C and watch the temp drop. It will hover around 210 until you get moving than it goes back to normal which for me is about 190-195.
Old Apr 5, 2002 | 02:14 PM
IPRESS's Avatar
IPRESS
What is the Hypertech PP?
Old Apr 5, 2002 | 04:43 PM
Mr Mojo's Avatar
Mr Mojo
A very expensive fan switch
Old Apr 5, 2002 | 05:13 PM
GlockLT4's Avatar
GlockLT4
Default Re: How hot should ? (Blk-94)
My normal coolant temp is right around 200. My fans are set to come on at 200 and turn off at 194.
To How hot should ?
