Winter Upgrades 2010....
Old Nov 18, 2010 | 02:14 PM
qwiketz's Avatar
qwiketz
Default Winter Upgrades 2010....
Hi guys. As you guys know I upped the boost on my ysi setup but unfortunately my trans can't hold it and is flaring on the shifts.
MoBandy swapped out his auto for a 6 speed for the electric vette and I'm picking up his 4l60e trans. Since I have a 92, I just ordered the controller box. I chose this one:
http://www.optishift.com/index.shtml
It'll be nice to finally be able to control my shift points and several other things on the trans.
I'm also picking up his converter as well. It's a 2400 rpm unit which is a little lower stall than I ideally would like, but it will definately help me quite a bit. Currently, I have a stock one and leave off idle. This one will definately chop down my 60' times.
We're installing everything on black friday, so I should have some pics shortly thereafter. I'm hoping to take the car to the drags, Dec 9th, 2 Thursdays from today. I'm taking the Jag to the drags on December 2nd to see what it'll do with the new ported blower and alky injection.
Old Nov 28, 2010 | 01:13 PM
qwiketz's Avatar
qwiketz
The trans is in the car but we're having an issue with the speedo which is causing the trans to go into limp home mode.
On a different note, the car finally has a stall converter which really woke things up. Even in second gear starting from a dead stop I can haze the tires at will. This thing is going to be an animal at the track now that I have more boost and a real torque converter.
Old Nov 28, 2010 | 04:57 PM
mnstrlt1's Avatar
mnstrlt1
Russ-
Good to hear everything is coming along. I can't wait to see the results at the track for both vehicles!
Old Nov 28, 2010 | 09:29 PM
qwiketz's Avatar
qwiketz
The car is up and running. I'm going to pick the car up tomorrow night. The install went fairly smoothly. We had some issues with the computer not interfacing with the speedo and the trans going into limp home mode.
Old Nov 30, 2010 | 11:33 AM
qwiketz's Avatar
qwiketz
I just got the car home last night. Everything is going pretty good so far with the exception of my speedo not registering. There is a difference between the vehicle speed sensor's signal on my trans computer and that of the ecu. Consequently, the abs doesn't work right now (because no speed is registering) and the iac doesn't kick in when you go from driving to idle causing the car to stumble a bit when cold.
The fix is more than likely a dakata digital box that will change the vss's signal into something that the ecm can see.
Other upgrades include repairing my b&b exhaust that is literally falling apart at the tube going into the muffler. There's a leak after being removed and reinstalled.
I'm getting a new set of drag radials of stickier compound to help me hook up at the drags. With the torque converter and a ton of torque, my bfgs (now worn out) probably won't hold the power. I also need to get an alignment to make the rears sit more flat (the wear to the inside due to the lowering of the car) and the front end needs work too(wearing on the outside of the tires).
I'm thinking of installing a new boost guage with recall, new fuel pressure sensor and possibly a dual channel wide band with data logging (to replace my single channel). All of these are done more for my safety than anything. The car is way too fast now to watch the boost and fuel pressure guages.
The last thing I need to do is adjust the plunger on the power brake booster. The pedal goes down too far before engaging the brakes for my liking.
Are those enough upgrades for this winter, lol?!
edit... I should relay my first impressions of driving the car with the new system. The torque converter is pretty fun. It's like learning to drive again for the first time. With a stock converter you push the gas and go. With a car with a stall converter it's like you push the gas and it barely starts to move and then ramps up. It's like feathering the clutch with a manual.
I was a little too quick on the pedal on the way home and did a bunch of peel outs. Going uphill in my complex with speed bumps was pretty tricky. Once I'm at the track, this thing is going to be killer and I'm going to absolutely destroy my previous best of 1.69 60 foot (and hopefully don't destroy my rear end!).
I'm going to play with the shift points (currently 5000 rpm in first and second) and also the part throttle shift points. This is going to be fun!
Old Nov 30, 2010 | 01:04 PM
BBExhaust's Avatar
BBExhaust
Premium Supporting Vendor
"Other upgrades include repairing my b&b exhaust that is literally falling apart at the tube going into the muffler. There's a leak after being removed and reinstalled."
qwiketz, sorry to hear you are having an issue with one of our mufflers. Give me a call at 888-228-7435 ext.18 and we can discuss getting this taken care of for you.
Mark Fowler
Billy Boat Performance Exhaust
888-228-7435 Ext.18
mark@bbexhaust.com
Old Nov 30, 2010 | 02:33 PM
qwiketz's Avatar
qwiketz
Thanks Mark, I'll get the pics over in the morning.
I called Mark and I'm going to send him some photos so that we can figure out a plan of action to repair the mufflers. That definately helps me out so that I can focus on the other small things!
Old Dec 1, 2010 | 01:57 AM
mnstrlt1's Avatar
mnstrlt1
pretty cool progess and plan of action... you "really" need to get some numbers for the FI forum before the year is out (or shortly there-after). Many of us are interested to see what kind of numbers a YSi on a 383 Lt-x makes! Not to mention track times.
What tires did you go with for the rear? Still sticking with 335's?
Old Dec 1, 2010 | 11:54 AM
qwiketz's Avatar
qwiketz
I'm probably going to go with the toyo ra1's for road use (the standing mile) and mt drag radials for the track. I'll probably stick with the 335's on the street, but really 315's whould be ideal for both. There's probably not going to be enough clearance for the 335's once I get my car aligned. Right now the rear tires are tipped in. There will probably be too much fender interference for the 335's.
It should make good numbers. I'm seeing more boost now than before. I'm seeing 10 lbs by 3500 rpm which was almost as much boost as I was seeing before max.
Old Dec 1, 2010 | 11:30 PM
95PCTBK's Avatar
95PCTBK
i got the same tranny controller for my 95. hopefully i can put the 4l80e in this week. if you would post your results with the speedo fix.
Old Dec 2, 2010 | 01:32 PM
qwiketz's Avatar
qwiketz
Nice! that 4L80 will definately handle some abuse. I'm pretty sure the dakota digital box is the solution. I'll discuss with Wayne and probably order one and get it installed soon. The box costs about $80.
Tonights going to be a quiet night on the Corvette. I'm heading to Irwindale 1/8 mile with the Jag!
Old Dec 3, 2010 | 01:17 AM
mnstrlt1's Avatar
mnstrlt1
Post the results for the Jag!
Old Dec 3, 2010 | 11:28 AM
qwiketz's Avatar
qwiketz
Haha! Last night was kind of a flop with the jag. It was pretty crowded so I didn't get that many runs in.
I wanted to run 2 with the alky on and 2 with the alky off to see and tune the system. My mph was the same as last time I went out despite better weather so I'm thinking the nozzle I'm using may be a little big.
I made 3 runs. The first one was with a passenger and I trapped just under 80. The second one I trapped at 80 even but I spun pretty bad in second causing the traction control to come on for about a second which killed my et and trap.
Finally on the 3rd run, my tires got wet so I totally spun off and on for at least 150 feet. At that point there was no way to drive around the water box(water was everywhere) and so my tires flat out would not hook.
Oh well.... next time I'm going to get there earlier and make a ton of hot laps with the alky on, off, and with the 375 and 625 nozzle. I'll see what works best. I was expecting about 85mph so maybe it's just the alky nozzle and alky controller settings.
Old Dec 3, 2010 | 01:25 PM
qwiketz's Avatar
qwiketz
Also, a special thanks to Wayne (MoBandy) for hooking me up with a great deal on his trans and helping me install it.
Another thanks to RacePro Engineering who sent me the battery hold down so that I can get my car track legal. I was previously missing the hold down.
Thanks to everyone else for the encouragement to get this bad boy done and on the track!
To Winter Upgrades 2010....
