94 clutch question...MAJOR chattering
Old Nov 21, 2010 | 02:21 PM
derekguzz's Avatar
derekguzz
Default 94 clutch question...MAJOR chattering
I have both main seals on my motor leaking which is being fixed now. I also had a power steering leak. So all this oil was pouring all over my bell housing/trany. Problem is, about 30k miles ago I had the clutch and flywheel replaced ( original lasted 150k) and the guy never put the guard back on. I am wondering if all my chattering could be because of it being oil soaked. Reverse is horrible like unusable. I am removing my motor for some work and will have the transmission out as well. I will see whats going on once its out but has anyone ever had an oil soaked clutch/flywheel problem? I am just trying to eliminate some things here
Old Nov 21, 2010 | 04:33 PM
sailorsteve's Avatar
sailorsteve
Chattering and/or grabbing are classic signs of an oil-soaked clutch plate.
Old Nov 21, 2010 | 04:46 PM
STL94LT1's Avatar
STL94LT1
Didn't I read some time ago that the chattering started after your clutch/flywheel replacement?
Old Nov 21, 2010 | 07:15 PM
derekguzz's Avatar
derekguzz
yes because before the replacement, the bellhousing had the guard on it keeping all that oil out. Now the guard is gone and its got sooo much oil and crap all over it.
Old Nov 21, 2010 | 07:20 PM
STL94LT1's Avatar
STL94LT1
The shield mainly keeps road debris out. If the rear main seal is bad the oil would be inside the shield.
Old Nov 21, 2010 | 09:25 PM
856SPEED's Avatar
856SPEED
it also could be from the type of clutch you replaced the other with....I once had a RAM "puck" type disc and it chattered extremely bad in reverse shaking the whole car violently......the one I have now chatters but not as bad (SPEC stage 2); also I am running a Fidanza aluminum FW....doesn't help much either....
Old Nov 21, 2010 | 10:06 PM
derekguzz's Avatar
derekguzz
I am running a stage 2 clutch and a stock used flywheel. I had a fidanza but it was horrible.
Old Nov 21, 2010 | 10:20 PM
383vett's Avatar
383vett
Did it start chattering immediately after the clutch change or did it start after a while when the disk might have gotten oil on it?
Old Nov 21, 2010 | 10:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
OIl would make it slip Id imagine.
Old Nov 21, 2010 | 10:49 PM
derekguzz's Avatar
derekguzz
I think it started a little after the install. I dont know if its bad installation or what because the guy that did my clutch/flywheel did my rear end 4.11 gears and those things whine like my brother.
Old Nov 21, 2010 | 11:05 PM
383vett's Avatar
383vett
Oil will usually cause major chatter.
Old Nov 21, 2010 | 11:07 PM
383vett's Avatar
383vett
Good one. So your car is now perfect except for the engine, transmission and rearend?
Old Nov 22, 2010 | 10:16 AM
derekguzz's Avatar
derekguzz
haha ya and the heater core isn't even leaking either !!..Its my second car and my dad bought it brand new in 94 so it has some value to me. I am just hoping I can get it to what it was before I started messing with it.
To 94 clutch question...MAJOR chattering
