Auto Trans Doesn't Shift
Old Nov 23, 2010 | 08:03 PM
lenoble22's Avatar
lenoble22
8th Gear
Default Auto Trans Doesn't Shift
When I was driving the car all of a sudden had only half power, oil pressure dropped in half and there was a clicking noise. I put it in neutral and then I had full power again. The noise is gone but now my car wont shift out of first gear. Maybe it only had half power cause it was stuck in 2nd gear??? Torgue converter?? any help appreciated. Thanks.
Old Nov 23, 2010 | 08:11 PM
C4vettrn's Avatar
C4vettrn
Did you check the level of your tranny fluid? Smell it to see if it smells burnt. When you say you only had half power was the motor reving up but the car wasn't going like it should?
Old Nov 23, 2010 | 09:59 PM
383vett's Avatar
383vett
Also check your motor oil level. Low pressure and clacking could be lifters clattering from low or no oil pressure.
To Auto Trans Doesn't Shift
