Transmission Fluid Question
Old Nov 23, 2010 | 11:59 PM
aj1988's Avatar
aj1988
Default Transmission Fluid Question
If you are replacing a transmission but keep the old TC how much fluid do you need before startup? I found instructions in a Haynes manual (since I also have the FSM I use the Haynes for the pictures) that says 23 pints. Haven't been able to find anything for how much is in the TC.
And if anyone wants, I am putting all the nuts and bolts I pull into baggies and putting the size on them, I will post where the nuts/bolts go and the wrench/socket size needed to turn them when I get finished.
Old Nov 24, 2010 | 10:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are you replacing the old fluid in the TC, too?
Old Nov 24, 2010 | 10:23 AM
383vett's Avatar
383vett
On my car (4l60e) replacing a new tranny with the old converter is about 8 quarts. New tranny with a new converter is about 11 quarts.
Old Nov 24, 2010 | 12:50 PM
aj1988's Avatar
aj1988
The transmission I am replacing only has about 1000 miles on it, blown front seal I think, so I will probably just leave the fluid in the TC.
Old Nov 24, 2010 | 05:51 PM
c4cruiser's Avatar
c4cruiser
I would take the car to a reputable shop and have a full trans flush done along with a new filter. The flush will swap out all of the old fluid.
Old Nov 24, 2010 | 05:58 PM
samsonb's Avatar
samsonb
I recommend the Felpro rubber gasket. No gasket mess to clean up next time.
Old Nov 24, 2010 | 08:14 PM
aj1988's Avatar
aj1988
The new filter came with the rubber gasket. I am going to drain the trans that is going in and change the filter. I know the fluid in the original tranny is still a nice shade of red.
Old Nov 24, 2010 | 10:27 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I changed the fluid in the TC in my `87 by draining the trans, changing the filter, & then got all the fluid out of the tc by using the return line at the radiator. I just kept adding a gallon of fluid to the trans for every gallon that came out of the return line, until the fluid coming out of the line was bright red. Its easy, all you have to do is hook a rubber hose to the return line, start the car & let it idle- & let the dirty fluid fill (in my case) a gallon container. Shut the car down, empty the container, put a fresh gallon into the trans, & repeat the process until the fluid coming out is clean.
To Transmission Fluid Question
