Pulley Noise
Old Nov 24, 2010 | 03:50 PM
ricknyc23's Avatar
ricknyc23
Default Pulley Noise
I have had a noise when the car is cold which sounded like it may be a pulley or belt. The noise would go away once the car was warm, so I didnt pay any mind to it. Today however, while driving, I started hearing this same noise. It was kind of intermittent. I dont have any codes showing up. Do you guys have any audio on what a pulley sounds like when its going bad?
Old Nov 24, 2010 | 04:00 PM
383vett's Avatar
383vett
Might want to check your power steering fluid. The pump can make weird noises if the fluid is low.
Old Nov 24, 2010 | 04:08 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
When its making the noise, spray some Armorall or similar product on the belt. If the noise goes away its the belt.
Old Nov 24, 2010 | 04:29 PM
ricknyc23's Avatar
ricknyc23
It was filed about half way while car is hot. Hot full should it be?
Old Nov 24, 2010 | 06:00 PM
derekguzz's Avatar
derekguzz
My dads C5 was making that noise. Got worse as time went on. Landed up being the water pump. Ask me how I found out.
Old Nov 25, 2010 | 03:13 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Take off the serpentine belt and rotate each thing by hand. If anything feels or sounds odd, that's probably your cause for the noise.
On my 94 LT1, the alternator and the idler pulley didn't feel right. Made a whistling sound when cold.
Old Nov 25, 2010 | 06:12 AM
littlesk8cracker's Avatar
littlesk8cracker
on my 94, idler pulley made a ton of noise when it was cold out. changed it and all is good
Old Nov 26, 2010 | 10:27 AM
sailorsteve's Avatar
sailorsteve
Does the cap on the reservoir have a dipstick on it?
To Pulley Noise
