Oil cooler adapter
Old Nov 24, 2010 | 06:00 PM
samsonb's Avatar
samsonb
Default Oil cooler adapter
Does anyone know the torque spec for the center shaft on the oil cooler adapter? It is the center piece that has a nut on it that the oil filter screws onto.
Old Nov 24, 2010 | 06:45 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You still that 150 ft torque wrench?
Never mind.......
Old Nov 24, 2010 | 08:29 PM
mrbillybob's Avatar
mrbillybob
Default Torque setting
I just put a Derale oil cooler on my 96 LT1. The instructions for the nut was 20 (twenty) foot pounds . Hope this information helps
Old Nov 24, 2010 | 11:06 PM
samsonb's Avatar
samsonb
Never mind.......
What's your problem that I use a torque wrench? You had the same type of comments because I used a torque wrench on the rear spindle nut instead of just standing on a bar and guessing.
Obviously shops must laugh about using a torque wrench too which is why people have problems with bolts/nuts falling off, and finding things cracked or bolts stripped or over torqued causing the bolt to break on removal.
Years ago I had the dealer change the oil. They over torqued the drain plug causing it to leak. So, I had to have a shop replace the oil pan. The book says you have to remove the oil cooler to change the pan.
So, that shop must not have torqued the shaft on the oil cooler enough. As recently, that piece unscrewed when I went to remove the oil filter. So, I figured it best to torque it to spec since I already have a torque wrench.
Old Nov 24, 2010 | 11:07 PM
samsonb's Avatar
samsonb
I appreciate it. I was going to guess 20 ft/lbs.
I had the oil pan replaced a while back because the dealer over torqued the drain plug causing it to leak. So, the shop must not have torqued the shaft down enough when they put the oil cooler back on after replacing the oil pan. As it unscrewed when I went to remove the oil filter later on.
Old Nov 24, 2010 | 11:27 PM
JrRifleCoach
Happy Thanksgiving.
Old Nov 25, 2010 | 01:28 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Are you sure it wasn't the oil adapter above the cooler? IIRC, there are studs that prevent turning of the cooler itself. I'm thinking (though probably wrong) that the adapter itself would have to be turning because of the studs "locked" into the adapter.
The center shaft of the cooler freely rotates to press the cooler up to the block but I don't remember the cooler rotating while it was tightened. That's because of those studs locked into the adapter.
I'd check to make sure your adapter is tight.
Old Nov 25, 2010 | 05:03 AM
samsonb's Avatar
samsonb
It's not the adapter on the block. I must have miss-worded my post when calling the cooler an oil cooler adapter.
The cooler body wasn't turning. It was the center shaft that was turning. The center shaft screws onto the adapter just like an oil filter. When I was unscrewing the oil filter, that center piece unscrewed instead. So, I kept unscrewing it until the cooler dropped down. Luckily the shaft is just held in place with a snap ring. So, I got it off and removed the oil filter without having to remove the cooler and drain the block. That snap ring looks to serve no purpose as there is no groove in the shaft for it. Must have been on there for assembly to keep the shaft in place.
The only thing holding the cooler on the adapter is the torque on the center shaft piece. I probably should have replaced the cooler gasket while it was dropped. I think most just use the gasket off an oil filter.
I've got the center shaft in the cooler screwed down on the adapter. I just needed to finish torquing it.
Old Nov 25, 2010 | 02:05 PM
383vett's Avatar
383vett
The oil cooler has an o-ring that seals against the block. It shouldn't have to be replaced. I've had mine off dozens of times and have reused the o-ring with no leaks. I tighten the center post moderately tight (whatever that is) and it hasn't come off. Good luck.
Old Nov 25, 2010 | 02:15 PM
GREGGPENN's Avatar
GREGGPENN
Gotcha!
Sounds like you've got a handle on it. Obviously, you just need to torque the adapter a hair more than your filters.
Old Nov 25, 2010 | 04:21 PM
samsonb's Avatar
samsonb
I was looking on the thirdgen board. And found a post that the oil cooler retainer gets 17 ft/lbs that came from a 90 Camaro FSM.
To Oil cooler adapter
