Help with part #'s
Old Nov 25, 2010 | 02:43 PM
simple green's Avatar
simple green
Default Help with part #'s
Hello friends,
I'd like to replace the front seal in my 94 LT1 , but am having trouble finding the correct p/n. Does anyone know off hand?
As well, is the seal replaced via removal of the timing cover?. If so, gasket p/n's?
Finally, what's the proper identification of the balancer puller?
Thanks all.
Old Nov 25, 2010 | 09:36 PM
STL94LT1's Avatar
STL94LT1
Felpro sells a timing cover gasket/seal set that includes timing cover gasket, water pump gaskets, and the three timing cover seals. Any auto parts store should be able to look up the number.
