Select ride control issues?
Old Nov 26, 2010 | 03:07 PM
TIMSTERS VETTE's Avatar
TIMSTERS VETTE
Default Select ride control issues?
Alright, anyone ever or still have issues with the Select Ride Option. On my 90, it has a mind of it's own, works when it wants to. At the present time, it is on performance. If this should quit altogether, am I in the S_ _t creek without a paddle?
Old Nov 26, 2010 | 04:59 PM
sailorsteve's Avatar
sailorsteve
Sounds like an electrical issue. Is the "service ride control" light on? If not, does the src light come on momentarily at startup, indicating the bulb is good?
Old Nov 26, 2010 | 06:28 PM
c4cruiser's Avatar
c4cruiser
Use the search function and enter "FX3" for the term. You will find results with lots of information that show you how to pull codes, what the codes mean and how to fix them. There are 12 possible trouble codes plus the start code.
Regardless of the year of the FX3 option, it's the center console **** you move to select the type of ride. With the SRC light on, the system should default to the Tour setting (biut it could also be Performance). In any event, with the Service Ride Control light on, the selector switch does nothing.
To Select ride control issues?
