Iron head LT1 Performance Question
Old Nov 27, 2010 | 08:36 PM
bootlegpass's Avatar
bootlegpass
Default Iron head LT1 Performance Question
I'm dropping a 1995 LT1 from an Impala SS into my 84. I know this engine is about 30-40 hp shy of the c4LT1. However, I understand that the torque numbers are similar. I'm considering 1.6 rockers and a cam that will work with the stock PCM to boost performance a little.
I have a set of 374 aluminum heads but I want to send them out for porting and valve work before using them. I also understand that these iron heads flow about the same as the aluminum (or a little better) than the 374's. I'm aware of timing and heat disapation, and don't want to get into that debate. I can't afford $1200 right now for the porting. In the meantime, what would be a good cam and, is the 1.6 rockers feasible? I plan to reuse them on the 374's when the time comes. Thanks in advance for all the help.
