Stripped Bolt in head
Old Nov 29, 2010 | 02:30 PM
choopes's Avatar
choopes
Default Stripped Bolt in head
I stripped the upper power steering pump bolt. No room to get a drill in there to drill it out and re-tap it or use a helicoil. I can't locate a self tapping jobber that big. I don't want to remove the head. There is still some bite. Only when I snug it does it strip. I thought about a little lock-tight. Any ideas thoughts or suggestions? I hope the next car I buy has a better work to drive ratio. (Work on it 8 hours, get to drive it 30 min before it tears up again). Thanks!
Old Nov 29, 2010 | 02:35 PM
WW7's Avatar
WW7
Helicoil or retap is the only way I know..Have you thought about using a right angle drill, you should have enough room to get that in there.You can get these at Lowe's, Walmart, almost anywhere, either air or electric.....WW
http://www.google.com/imgres?imgurl=...ed=0CC4Q9QEwAw
Old Nov 29, 2010 | 02:40 PM
JackDidley's Avatar
JackDidley
Buy some locktite thread restore. Use that and install a stud instead of a bolt. It will work.
Old Nov 29, 2010 | 02:41 PM
overdrawn's Avatar
overdrawn
For a one time shot...rent one
Old Nov 29, 2010 | 02:45 PM
WW7's Avatar
WW7
Dude , you always have good ideas...this would definitely be the first thing to try....WW
Old Nov 29, 2010 | 02:57 PM
JackDidley's Avatar
JackDidley
Thanks. You dont put 200,000 miles on a C3 without learning a thing or two.
Old Nov 29, 2010 | 04:11 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Good idea, or get some 2 part devcon thread restore. it has some mould release in the kit.
Old Nov 29, 2010 | 04:13 PM
choopes's Avatar
choopes
Thanks Jack! If I can ask a dumb question. What's the difference between a stud and a bolt? I thought a stud was a bolt.
Old Nov 29, 2010 | 04:15 PM
383vett's Avatar
383vett
Why would you have to remove the heads to repair a water pump mounting bolt? Those are threaded into the block.
Old Nov 29, 2010 | 04:16 PM
JackDidley's Avatar
JackDidley
Stud has no head. Thread it in and put a nut on it.
Old Nov 29, 2010 | 05:09 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I wish you could see my face when I saw the thread title
Old Nov 29, 2010 | 05:37 PM
choopes's Avatar
choopes
The stripped threads are in the power steering pump mount. Top hole. Sorry. It's been a long frustrating day. Where do you buy devcon thread restore? Will it take the heat?
Old Nov 29, 2010 | 07:34 PM
RichS's Avatar
RichS
That whole bracket comes off with 3 more bolts. Then it would be much easyier to put in a helicoil.
Old Nov 29, 2010 | 07:57 PM
383vett's Avatar
383vett
That would be the way to go. Shouldn't take too long. If there is not enough room, use a right angle drill.
Old Nov 29, 2010 | 08:33 PM
92WhiteVetteGuy's Avatar
92WhiteVetteGuy
Chemically clean out the threads and try inserting a correct size/length nut/stud and some Loctite "Stud and Bearing Mount".
Not cheap! Last time I bought some was $20 about 35 years ago.
Will need to be heated to remove.
Good Luck,
Old Nov 30, 2010 | 06:24 PM
turbotim23's Avatar
turbotim23
Or you could use Jb weld to glue a stud in there. Just be sure to get it in straight. When I had my trans am I had the alternator bolt mount in head break away. I didn't want to take the head off and there wasn't enough metal left to fix it[one side of bolt hole was completely gone] . So I JB welded a threaded rod in the head. Trouble was I didn't get it glued in exactly straight. I was able to bend it where I wanted it with a crow bar, without braking the JB weld. I beleive JB weld can also be drilled and tapped if you wanted to fix it by cleaning & filling hole and then drill and tap hole to right size again. This wouldn't be as good as a helicoil but it would be a lot cheaper and easier. JB weld is good stuff I use it all the time now.
Old Nov 30, 2010 | 06:44 PM
383vett's Avatar
383vett
I agree JB Weld is good stuff and I've used it many times. The only problem with JBing a stud in the accessory holes of a head is that many machine shops use these holes to hold the head down when machining the heads; valvejobs or valveguides. Could make it somewhat difficult in the future.
To Stripped Bolt in head
