Power antenna
Old Dec 1, 2010 | 12:54 AM
overdrawn's Avatar
overdrawn
Default Power antenna
My antenna will go up but not down, I can hear the motor running so it should be repairable, just woundering what would be the best way to remove it and what part do I need to repair it... 92 convertible ,Thanks
Old Dec 1, 2010 | 10:19 AM
sailorsteve's Avatar
sailorsteve
You probably need the plastic ribbon that goes inside the antenna shaft, it has teeth that eventually become toothless. Not a difficult job and most aftermarket vendors have this piece.
Old Dec 1, 2010 | 11:32 AM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
C4 Corvette Antenna
C4 Antenna Repair Article
We offer both the repair kit and a replacement antenna, though at the moment we are out of the antennas themselves.
Feel free to call with any questions
Tom 1-800-862-9632 ext 240.
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Dec 1, 2010 | 04:44 PM
overdrawn's Avatar
overdrawn
Thanks guys, but how do I get to it? Through the wheel well?
Old Dec 1, 2010 | 08:49 PM
l98tpi's Avatar
l98tpi
Max G’s
The motor itself is accessible from underneath the car at the rear behind the wheel well. It is easiest to raise the car up on jack stands.
But if you only need to replace the mast, there are directions for replacing the mast without removing the motor. You would only need to remove the motor if you have some of the old mast (plastic ribbon) broke off in the motor.
Old Dec 1, 2010 | 09:09 PM
overdrawn's Avatar
overdrawn
Hey thanks, I'll order the part and see.I quess you would just thread it down into the motor?
Old Dec 2, 2010 | 10:09 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
How to replace a C4 Corvette antenna mast
by Julian Shipp
Here are the instructions for removing the power antenna motor for service BEFORE installing a new antenna mast on 1992-1996 Corvettes.
The power antenna motor is visible from underneath the vehicle if you lay on your back and look at it from the driver's side of your car. Please protect your eyes from dirt and other particles that may fall from your fender well while you are working! Some people have opted to place their vehicles on jack stands and remove the driver's side rear wheel first, but I have long arms and did not have to do so.
1. Disconnect the negative battery terminal. Note the way the motor is oriented as installation is the exact order of removal. The motor is held in place on its mounting bracket by two screws. Use either a socket wrench with an extension or a screwdriver with a ratchet to remove the bolts. Note that one of the bolts has a ground/power wire for the antenna.
2. With these two bolts loosened, you will be able to pull the antenna down toward you enough to loosen the antenna gain and positive power wires located at the top of the unit. With all these wires removed, the entire assembly can be pulled down for access while leaving the wire that lead inside the motor housing intact.
3. With the unit now in your hand, roll up the black rubber sleeve that protects the unit from moisture, dirt, etc. There are approximately four Phillips head screws that hold the cover on the motor housing. Remove these screws. Also, remove the center nut that holds the antenna flywheel in place. With the cover off, you will see the flywheel and the main gear that raises and lowers the nylon antenna ribbon. You will also more than likely find bits or long sections of your OLD ribbon. Remove them.
4. Now is the time to lubricate the main gear and flywheel with either Vaseline or white lithium grease to ensure years of trouble-free operation with your new ribbon.
5. Replace the flywheel (noting its direction) and screw the cover back into place. Re-install the antenna, connect all the wiring and hook your battery back up. Turn on the ignition and radio and listen to see if the motor runs. If it does, you are ready to install your new mast.
Just follow the directions that came with it and you should be in great shape. Above all, be patient. It took me about four hours the first time I did this because I thought you had to remove the license plate, tail lamps and back up lamps to get to the motor. You don't! I could now do the whole thing again in 30 to 40 minutes (but hopefully not on MY LT-1 any time soon!)
To Power antenna
