Engine Check Light Question?
Old Dec 1, 2010 | 03:06 PM
Jim McCombe's Avatar
Jim McCombe
Default Engine Check Light Question?
My 87 is nearing the due date for the dreaded smog check and I have noticed recently that the engine check light does not come on now when the key is in the on position.
Other functions such as battery etc display but not the engine check light which is required.
Could it be the bulb or something else and how much trouble is it to remove the display panal?
Any help would be greatly appreciated....
Thanks,
Jim
Old Dec 1, 2010 | 06:57 PM
rodj's Avatar
rodj
For starters, pull the DIC and swap a working bulb from one of the other lights into the SES socket and see if it lights up.
If it doesn't , you have problems elsewhere
