Th700 with strange "noise" ?
Old Apr 6, 2002 | 10:45 AM
devilfish's Avatar
devilfish
Default Th700 with strange "noise" ?
I have noticed that when the car is in D, I have a ratteling metalic sound from under the car, sound like something is loose. The sound disapear when putting the tranny in P or N. The sound comes and goes but only when in D or [D]. Could it be something with the TC?
regards
[Modified by devilfish, 5:05 PM 4/6/2002]
Old Apr 6, 2002 | 07:05 PM
devilfish's Avatar
devilfish
Default Re: Th700 with strange "noise" ? (devilfish)
tt ?
Old Apr 6, 2002 | 07:47 PM
Sharky Guam's Avatar
Sharky Guam
If you do not notice a difference in performance, I would guess that it is a loose bracket or exhaust heat shield. Putting the car in gear causes extra vibration in the drivetrain which amplifies any vibration from a loose part.
Jack up the car frist and check for anything loose. It may be a cheap fix.
:yesnod:
Old Apr 7, 2002 | 12:57 PM
devilfish's Avatar
devilfish
Default Re: Th700 with strange "noise" ? (Sharky Guam)
could this be something to worry about?
Old Apr 7, 2002 | 01:34 PM
snydcat's Avatar
snydcat
regards
My car was making the same kind of sound only in D and it turned out to be the clamp coming loose that holds the tube coming from the catalytic convertor. I had to tighten it every 6 months or so until I just took the damn thing off and I haven't had a rattle since, that was over a year ago.
Rich
Old Apr 7, 2002 | 02:32 PM
devilfish's Avatar
devilfish
Default Re: Th700 with strange "noise" ? (snydcat)
could be. 2 weeks ago I had my exhaust down. So it could be the "tube" :) thanks
To Th700 with strange "noise" ?
