Distributor Cap/Rotor Replacement
Old Apr 6, 2002 | 05:23 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Distributor Cap/Rotor Replacement
I'm in need of a new cap/rotor. MAD sells the factory AC Delco Cap/Rotor for $16.99, and they also sell an Accel high-perf cap/rotor for $28. Does is make a difference which one to go with?
Old Apr 6, 2002 | 08:39 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Distributor Cap/Rotor Replacement (FlyboyZR1)
:cheers: 12 BUCKS! Stay with the GM!
There Ignition parts are tough to beat!
:seeya
Old Apr 6, 2002 | 10:48 PM
86VetteBill's Avatar
86VetteBill
Default Re: Distributor Cap/Rotor Replacement (jackdaroofer)
Huh? $12? Where at? Pep Boys? GM? Trak?
Old Apr 6, 2002 | 10:52 PM
scorp508's Avatar
scorp508
He meant $12 difference between the stock and Accel. :)
Seriously, the stock ignition is very hard to beat for the stock cars. They'll put out enough power for more RPM than a stock L98 will even turn.
Old Apr 6, 2002 | 11:06 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Last Delco cap I bought for the Corvette was a really lousy casting. Looked like it would carbon track in no time. I returned it. If you would have asked me this a year ago I would have said go with the Delco cap, but this cap was really not well made.
Last Accel cap I bought was a really nice casting. Clean and smooth, good contacts as well. I think it was worth the extra cost.
Old Apr 6, 2002 | 11:08 PM
86VetteBill
Default Re: (scorp508)
Aaaahhhhhh.....
And I thought $28-16.99 would be closer to $11.01 !! :D
Old Apr 6, 2002 | 11:10 PM
pablocruise's Avatar
pablocruise
I've had bad luck with Accell caps. 3 caps with premature corroded terms.
I run an MSD cap and rotor. On my 89, I had to mod the cap from the spring loaded "L" hold down to a screw down cap. MSD doesn't make screw down caps for my year dist.
Old Apr 6, 2002 | 11:23 PM
paid4c4's Avatar
paid4c4
Flyboy;
Stay with Delco for a stock application. HEI is one system GM got right, before they started the OPTICRAP. I just changed my cap and rotor on our
L98, 90 Droptop, runs like a champ!
Good Luck
Bill :) :)
Old Apr 6, 2002 | 11:27 PM
8388's Avatar
8388
St. Jude Donor '14
Default Re: Distributor Cap/Rotor Replacement (89 Paul in cal)
Delco or MSD depending on the application. MSD makes a good product, I've used their Distributors and they are a precision piece, well worth the money.
Old Apr 7, 2002 | 05:45 AM
65Z01's Avatar
65Z01
For a little more power, try a HyperTech coil/cap/rotor, some TPIS wires and open up those Delco plugs.
In any case do the cap and rotor together.
Old Apr 7, 2002 | 09:06 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Distributor Cap/Rotor Replacement (65Z01)
This is one area to save your money and buy a Delco cap.
:seeya
To Distributor Cap/Rotor Replacement
