Question about installing CAMBER BRACE
Old Apr 6, 2002 | 06:54 PM
Kale's Avatar
Kale
Default Question about installing CAMBER BRACE
Ok, so when i pull the bolt out of the suspension, is anything going to fall out, go otu of alignment, fly into the air, or generally be hard to put back together? or will it stay lined up?
Old Apr 6, 2002 | 07:00 PM
Ross96coupe's Avatar
Ross96coupe
Default Re: Question about installing CAMBER BRACE (Kale)
I did my camber brace 3 weeks ago. When you remove the bolt, everything will stay in place. Be sure to use the provided shims. :flag
Kale's Avatar
Kale
Default Re: Question about installing CAMBER BRACE (Ross96coupe)
Thanks! Only looks like one hard spot to fit it through, by the A/C lines... well, we'll see.
Old Apr 6, 2002 | 11:06 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Do I have to jack the car up? I don't have a jack low enough :rolleyes:
Old Apr 6, 2002 | 11:51 PM
GS 163's Avatar
GS 163
Default Re: Question about installing CAMBER BRACE (vettes rule)
Yes, you have to jack it up. I drove mine up on a couple boards to get enough clearance.
To Question about installing CAMBER BRACE
