steering wheel removal trouble
My 84 came to me without a horn button, or contact, contact wire, and a broken lead tower.
I went to put the contact and lead tower in today and for the lead tower, the steering wheel needed to come off.
The puller I used has a little safety washer that goes onto the end, but was not quite long enough to protect the threads in the center shaft. The screw to hold down the telescopic lever simply cannot make it back into the hole. My experience with a tap has not been pleasant to date, so I am just going to drive without the telescopic function. Worse than that of course it that it's the locking of the telescoping wheel that isn't going to work, the wheel will fly in and out all day long. I'll update you all with just how annoying or unsafe this is.
So, the advice: when pulling the steering wheel with a puller, be sure that you do not damage those threads.
No, really sounds dangerous to me.
I wasn't using the forum as a blog or bragging about being unsafe. For your information, having the telescope not lock was not a problem and is fine.
You've done nothing to contribute to the thread, other than inserting 2 cents worth of a **** comment you wouldn't dare say to me in person, treating the thread and this forum like a personal attack board, you may eat my *****.
For those that didn't follow.
In the pic, at the pullers end will go the black washer. On most pulelrs, it won't allow that puller tip to protrude much at all. On the puller I had, it protruded too much, damaging the threads that the locking screw enter at the end of the shaft.
Not surprised as he didn't help much on that thread either.
