Takes two tries to start car...?
Old Dec 8, 2010 | 01:11 PM
bolowbc's Avatar
bolowbc
Default Takes two tries to start car...?
Hey all,
My daily driver '95 just started having a funny symptom now that the weather here is getting cold (oil/coolant temps read "LO" instead of a double digit number now).
When I turn the key, I'll hear the engine start to turn over, but it putts out immediately. Then on the second try (after I wait 5-10 seconds), it starts up just fine. This has happened for the last 3 consecutive times.
Current oil weight is 10w30. Do I need to change it to 5w30? Is this an electrical issue? I believe the alternator and battery are in good condition. Overall the LT1 is in good shape, had a blown headgasket a year ago and many things were replaced including plugs/wires/opti.
Also, there is a noticeably loud humming noise that sometimes starts soon after ignition. I never really paid attention to it because everything seems to be fine. Not sure if that's what the fuel pump sounds like or the fans.
Thanks,
Will
Old Dec 8, 2010 | 01:24 PM
383vett's Avatar
383vett
Check your fuel pressure, then make sure your plugs, wires, distributor and rotor and in good shape.
Old Dec 8, 2010 | 01:32 PM
bolowbc's Avatar
bolowbc
Editted my post above. I don't know exact numbers, but fuel pressure climbs after I start my car according to the gauge. I don't remember seeing any strange fluctuations or ranges out of the ordinary.
Old Dec 8, 2010 | 02:29 PM
ZexGX's Avatar
ZexGX
If it's the fuel pump, the humming should be coming from the back, right? Locate where the humming noise is coming from... If it's the original fuel pump from '95 then I wouldn't be surprised.
Old Dec 8, 2010 | 02:37 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Weird. The new Ducati Monster 1100 has exactly the same problem.
Old Dec 8, 2010 | 02:54 PM
F22's Avatar
F22
When was the last time you changed the fuel filter? That loud humming noise you hear, might be the fuel pump in your gas tank straining against a clogged fuel filter. I'm having the same problems (no fuel pressure for 8 seconds) on the 87' and the fuel filter hasn't been changed for years and years!
Old Dec 8, 2010 | 05:12 PM
C409's Avatar
C409
...... Just like the lawnmower .............
Old Dec 9, 2010 | 12:03 AM
bolowbc's Avatar
bolowbc
Is it possible it's the battery? When it "putts out", I mean this is a split-second within the time I turn the key. I also noticed that the digital readout got all jumbled. If memory serves me, I think the display doesn't get all fubar when starting the car...
Haven't changed it ever, had the car for about a year. The humming noise comes from the front (engine bay)... possibly near driver side though.
Old Dec 9, 2010 | 08:10 AM
STL94LT1's Avatar
STL94LT1
It sounds fuel related. Do a fuel pressure leak down test. This will tell if it's a bad fuel pressure regulator or fuel pump check valve.
Old Dec 9, 2010 | 10:05 AM
lt4obsesses's Avatar
lt4obsesses
Cold weather has plays all kinds of funny tricks on cars.
Question, Does it do this on cold start only, or every time?
The whining, buzzing, noise could be the AIR pump, the alternator, or the compressor. Again, on cold start only?
The "lo" reading means that the oil and coolant are below 32*.
Everyone seems to point to fuel, and this may be. But I would look to electrical first. How old, and what condition is the battery? We all know what freezing temps do to batteries and ours seem to be especially vunerable due to their location.
Also, if you can, try to make sure your plugs and coil connections have a coat of dielectric grease. This will help to insulate against condensation issues.
Another thing I like to do, as I drive her year around, is when I know the overnight temps are going to be below freezing, I will take her for a drive later at night to get everything nice and warm. This helps to reduce the cooling effect and keeps a fresh charge on the battery to protect against the freezing temps.
Old Dec 9, 2010 | 01:57 PM
bolowbc's Avatar
bolowbc
I had the regulator replaced roughly 6 months ago when it malfunctioned and repeated non-starts flooded the cylinders :P
Those are some good tips, thanks! I may start doing late night drives. It's going to be tough to get out in the cold from the toasty warm indoors though.
It has only happened on cold starts. Strangely enough, it didn't happen this morning. Not sure how old the battery is.
Old Dec 9, 2010 | 02:29 PM
sailorsteve's Avatar
sailorsteve
The humming noise could be the cooling fans coming on. You shouldn't have to mollycoddle your car for "cold" nights in your part of the world- Where I live winter temps occasionally approach zero, no starting issues. Re your oil question- for my LT1, a '92, GM specs 5w30.
If you are seeing a hesitation in cranking to start, maybe a winding in the starter is getting weak.
Old Dec 9, 2010 | 08:55 PM
bolowbc's Avatar
bolowbc
Hmm... you could be right. It happened again when I was getting ready to go home. It almost sounds like the engine turns over but it cut off suddenly. I'm bringing the car down to a shop tomorrow to install some shocks... I'll find out what it is and report back.
Old Dec 9, 2010 | 09:16 PM
Orr89rocz's Avatar
Orr89rocz
Might not be getting the right fuel mixture due to being too cold. This could be electrical in the battery or possibly even a bad IAT type sensor.
If you start to crank it over and hold the throttle down all the way does it start on the first try?
If it starts fine when the engine is warm or when on a cold start when its warm outside, then I dont think its getting enough fuel. Cold starts typically take much more fuel to start up
To Takes two tries to start car...?
