Don't the manufacturer's usually underrate the horsepower to satisfy the insurance industry?
I believe HP is always based on a minimum number for any vehicle so that there can't be any legal claims.
or, maybe it was underrated so that the LT1 sales wouldn't drop...just like the 'underrated' lt4 argument v.s. the ls1...lol :
I thought about that possibility after I posted, and think they would definitely at least use the exhaust manifolds/headers. I would still vote the bump in compression is more likely....but who knows what the general was doing for sure.
Mine originally had the "performance package" (supposed good muffler, 3.07 gear). The stock exhaust has been off the car so long now I don't remember if both outlets worked. I guess they probably did according to the other poster. To me it didn't matter, the car was a stone and thats why it needed some real changes. I do remember this was debated back when I first came on the board though..
I can say that my 91 one owner 83000 mi. all records ( I believe ) vette came with flat-top 4vr mahle cast on underside pistons. A stuck lifter and intake manifold coolant leak along with reseal and ring,bearing,bowl blend,clean,paint,ect., was the reason for the teardown. I can tell you the bores, crank, pistons, bearings, all looked and measured good and well within tolerance.
I changed out the pistons in my '89 last fall. They were dished with 4 valve reliefs. I went with flat top Speed Pro pistons with 4 valve reliefs. My comp ratio should be around 10.5:1 with me decking the heads about 0.010".
Are those hypereutectics ? when i did my engine rebuild i bought Mahle Flat top .030Hypereutectic pistons now with AFR 195 65CC heads and Victor Reinz 5746 head gaskets
Compressed Thickness (in) 0.026 in. Compressed Volume (cc) 5.400cc im very curious about my current Compression Ratio !
i found a link : http://malloryignition.racerswholesa...m?InvKey=62848
Compression ratio 64cc-10:1, 76cc-9:1
But not sure if its accurate
MAHLE makes very GOOD pistons Sammy.
Those are some strong pistons you have in '87 C4.
Hypertenutic is a good choice for street/ strip use.
Last a long time for You.
And you can do your own EFI tuning.
A big bonus for you also.
Less than a 1 month of Summer here Steve..........
Winter has to be closing in to an end there down under in Australia.
Have to be thinking alot about driving/making some fast 1/4 mile runs with your 1987 Black Vert & racing the "Heavy Metal Ford Cleveland Sedan too ............
Try & get on C4 again in a few hours to chat later Steve,
Goodnight Brian ! im goin to sleep as well 3:30 am here
Lemme,nice picture,never seen a clean stock 87 piston before
my original ones went straight to the trash can !
Need sleep here.
Brian
Yes summer is coming but I have another c4 on standby. My next challenge is getting the pistons back in the engine. Just ordered a piston ring compressor from Summit. Another week to wait.
Thanks Lemme !!!
but i've read the pistons are 12 cc,maybe im wrong ?
I think the dished ones are 12 cc (mine for instance). Flat tops only have the valve reliefs which I thought were just 3 cc. Someone else hopefully can confirm or otherwise.
